Where to get itr swaybar bushings?
:scratching head because these are questions only idiot noobs tend to ask? not someone being a memeber of 2002:
if you have oem bushings, there will be a number on the side of the rubber bushings (22, 24,25 depending on what you actually have) that will tell you what size to get, assuming everything is oem. if your bushings are black i will assume they are stock, hence get new ones at dealership.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 »</TD></TR><TR><TD CLASS="quote">I know ES makes some with zerk fittings.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr1244 »</TD></TR><TR><TD CLASS="quote">soo you mean ES ones fitments bad?? </TD></TR></TABLE>
what? where did you get that?
Jim was saying that they make some with zerk fittings which allow you to grease the bushings without taking them apart.
and the swaybar sizes are 24mm front and 22mm rear
WhiteOnRice
Oct 25, 2006 06:58 PM
