under steering wheel fuse cover??
Old Apr 11, 2007 | 07:32 PM
kuki22's Avatar
Default under steering wheel fuse cover??
hey guys i have a 97 ek coupe auto. the under steering wheel fuse cover is missing. my lights for the auto shifter are out. any one know which one is the fuse so i can check if its blow? a pic of the cover thats shows wut everything is would be nice also. also i bought the car and teh radio stock harness was hacked. does any one know the colro codes for the stock harness?????
Old Apr 11, 2007 | 07:40 PM
SomedaySoon's Avatar
Default Re: under steering wheel fuse cover?? (kuki22)
Just do a simple search on H-T and Google. I had the same problem with my Si, but I just searched around on Google and forums and found a fuse box diagram.
Good luck.
Old Apr 11, 2007 | 07:59 PM
kuki22's Avatar
i tryed..got nothing
Old Apr 11, 2007 | 10:00 PM
kuki22's Avatar
ok heres wut hapned. the people i bought the car from spliced a 98 up stock harness to the 97 stock harness. i dunoe if it is in there correct. can someone help me and tell me how teh wires should look or go 2 gether. 97attaching to stock 98 wires....
Old Apr 12, 2007 | 05:44 PM
NOFX's Avatar
H-T White Ops
From my USDM '98 EX coupe.
Old Apr 12, 2007 | 06:40 PM
kuki22's Avatar
wut number fuse is the light where teh auto shifter is? and wut size fuse should be in there?
Old Apr 12, 2007 | 07:44 PM
NOFX's Avatar
H-T White Ops
Default Re: (kuki22)
Do you mean the gear selection lights next to the shifter (do auto Civics have those?) or do you mean the dash indicator for gear selection in your gauge cluster?
Old Apr 12, 2007 | 08:07 PM
kuki22's Avatar
gear selection next to shifter.i dont think there are any on teh dash..
Old Apr 12, 2007 | 08:25 PM
EG8R's Avatar
Your bulb is burnt out. There is only 1 bulb in there.
<--- Is a Honda tech by trade...
Old Apr 12, 2007 | 08:36 PM
NOFX's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kuki22 &raquo;</TD></TR><TR><TD CLASS="quote">gear selection next to shifter.i dont think there are any on teh dash.. </TD></TR></TABLE>
There is an indicator in the gauge cluster too.
Old Apr 12, 2007 | 09:25 PM
kuki22's Avatar
how do u change teh bulb in teh auto shifter?
Old Apr 13, 2007 | 04:11 AM
monicle's Avatar
you pop the plastic piece out, you take the old one out, and put a new one in. pretty straight forward dude.
take a couple minutes to look at it and you can figure it out on your own.
Old Apr 13, 2007 | 04:58 PM
kuki22's Avatar
Default Re: (NOFX)
my cluster dosent loo like that. i have no display for teh gear ratio on it. engine temp yo left gas 2 teh right and speddo in middle
Old Apr 13, 2007 | 06:07 PM
NOFX's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kuki22 &raquo;</TD></TR><TR><TD CLASS="quote">my cluster dosent loo like that. i have no display for teh gear ratio on it. engine temp yo left gas 2 teh right and speddo in middle</TD></TR></TABLE>
That's really strange that you wouldn't have a gear selection in the cluster since '96-'00 Civics with automatics have them.
DX coupe:
EX coupe:
HX coupe:
What trim is your Civic? You said it was a coupe earlier, but it sounds like you have a manual CX hatch cluster.
Old Apr 13, 2007 | 07:16 PM
kuki22's Avatar
thas exactly wut it lookc like. if the personhwo owned it b4 me wanted could they install that cluster in my auto and it would work?
Old Apr 13, 2007 | 07:23 PM
kuki22's Avatar
so r teh light by the auto shifter suppose to even light up then???im goigng to by the correct cluster..
Old Apr 13, 2007 | 07:33 PM
NOFX's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kuki22 &raquo;</TD></TR><TR><TD CLASS="quote">thas exactly wut it lookc like. if the personhwo owned it b4 me wanted could they install that cluster in my auto and it would work?</TD></TR></TABLE>
Yes.
I'm pretty sure the display next to the shifter is supposed to work, but I don't drive an auto.
Old Apr 13, 2007 | 07:37 PM
kuki22's Avatar
ok..so ima buy a cluster for 20 bucks n fix dat problem hehe.. thank bro. now just gota figure why teh lights next 2 teh shifter dont work
Old Apr 15, 2007 | 09:32 PM
EG8R's Avatar
It's because your bulb is burnt out. I think there is maybe 4 or 6 phillips screws and you will have it out.
Old Apr 16, 2007 | 09:12 PM
kuki22's Avatar
thanks for teh help guys.. car is going up for sale as we speak. found a 2000 si for good price so im buying that
Old Apr 16, 2007 | 09:14 PM
kuki22's Avatar
hey they also choped da stock harness. do any of u guys know the wire color code on a stock wire harness. the previous owerner tried to splice a 98 harness but it isnt working. i could also use da 98 up harness colro code. its eriteh r98 or 2000. i know its a blue plug. and my 97 should be white
Buktheng
May 29, 2009 08:40 AM
lucas_69bus
Jun 19, 2007 02:07 AM
hawjboi
Aug 17, 2004 05:17 PM
XxSOHCDriVerxX
Oct 1, 2003 06:24 AM
