interior paint project
Old Apr 11, 2007 | 03:22 PM
racingcrx's Avatar
Default interior paint project
was painting interior pieces,
painted speaker covers and bubbles appeared.
not sure why this happen but we used dupli color paint for this project, was clean before paint.
does anyone know how to prevent these bubbles?
TIA.
Old Apr 11, 2007 | 03:31 PM
m0nee's Avatar
Default Re: interior paint project (racingcrx)
use wax and grease remover
Old Apr 11, 2007 | 04:09 PM
Yellowone's Avatar
Default Re: interior paint project (m0nee)
Primer them or just use some adhesion promoter
Old Apr 11, 2007 | 04:26 PM
kiddcarbuff's Avatar
use a DYE like one from SEM or the duplicolor vinyl and fabric dye, not regualr spray paint.
Old Apr 11, 2007 | 05:02 PM
racingcrx's Avatar
do you mean use wax and grease remover before applying paint?
Old Apr 11, 2007 | 05:04 PM
racingcrx's Avatar
Default Re: (kiddcarbuff)
i think that might be a reason.. i am using acrylic enamel paint..
Old Apr 11, 2007 | 06:07 PM
yea, get the vinyl DYE. follow instructions for prep on the back of the can, i did my CB7s bule interior to black this past week. looks and feels oem, ive dropped keys, tools all kinds of **** on the dash w/ no scratches
Old Apr 11, 2007 | 06:25 PM
alleyezonme's Avatar
10 thin coats are better then a couple heavy
Old Apr 11, 2007 | 06:28 PM
smileycvc's Avatar
Default Re: interior paint project (alleyezonme)
you layed the paint on to thick and it wasnt clean enough before you started.
Old Apr 11, 2007 | 06:32 PM
93eg2james's Avatar
Default Re: interior paint project (smileycvc)
Also, try shaking the can more.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kiddcarbuff &raquo;</TD></TR><TR><TD CLASS="quote">use a DYE like one from SEM or the duplicolor vinyl and fabric dye, not regualr spray paint.</TD></TR></TABLE>
Good idea. Here' a DIY on how to do it right.
Old Apr 11, 2007 | 06:34 PM
VRD^don's Avatar
[QUOTE=racingcrx]was painting interior pieces,
TIA.
QUOTE]
clean clean clean...clean the surface VERY Good..thats the reason why it turned out like that..even though u think its clean enough clean it a second time to make sure its clean..
Old Apr 11, 2007 | 07:03 PM
racingcrx's Avatar
Default Re: interior paint project (VRD)
i guess now it time to remove all the screwed painted pieces with brake cleaner from what i hear on different threads and redo by CLEANING 2x with some rubbing alcohol and repaint with proper vinyl paint.
btw.. i was trying to save an extra 1.50 with the dupli ... and now end up spending another 13 for 2 more cans.. doh
Old Apr 11, 2007 | 07:14 PM
Libertariat's Avatar
Ek Forever y0!
Too thick and using the wrong Ish.
Vinyl dye son.
Painted interior panels FTL
Old Apr 11, 2007 | 07:24 PM
93eg2james's Avatar
Default Re: interior paint project (ek forever guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">Too thick and using the wrong Ish.
Vinyl dye son.
Painted interior panels FTL </TD></TR></TABLE>
Unless it looks completely stock!
Ameripol FTW
Old Apr 11, 2007 | 08:01 PM
dad0c402's Avatar
Use Duplicolor vynl and fabric paint. Get flat paint for a factory look and use a protectant to get it glossly or do what 93eg2james did and paint it with gloss Works great, goes on looking like any other paint maybe thinner, but the details of the panels come out as it dries and becomes more of a dye. Just put the work into the prep work and the result will look great and last long. Don't prime or smoothen the surface if you want the factory pattern, just clean real good and with a brush.
Also 93eg2james I painted the plastic peices on the door to flat black as well and the paint works amazing on plastic. Just letting you know in case you didn't cuz I see your great door handles
btw I'm in the process of painting my interior black(left) because the power doors I ordered came in grey(right) and my interior is dark gray(middle), also waiting on the tweed for red inserts.
J.HU3ZO
Paint and Body
Apr 12, 2013 11:51 PM
91grape
Jun 27, 2012 10:48 PM
ervstr
Paint and Body
Feb 4, 2010 02:23 PM
spens 91 Ef
15
May 13, 2009 01:43 PM
freakasis
Paint and Body
Sep 17, 2008 04:07 PM
