plx m-300 wideband install
Old Apr 11, 2007 | 02:12 PM
94typeR's Avatar
Default plx m-300 wideband install
i plan on installing the wideband unit in my glovebox.
i have a pretty good idea on how to wire up the power and ground.
what i need help is, how do i route the wire through the firewall connecting the m300 unit and the wideband o2 sensor on my test pipe? what hole on the firewall should i go through?
also, how can i run only 1 o2 sensor using the m300 o2 sensor going to both the m300 unit and the ecu so i dont throw a code with future datalogging capabilities???
please help
Old Apr 11, 2007 | 02:30 PM
Relic1's Avatar
the M300 has a simulated narrow band outpuf for normal use so you can run it all the time. I've had mine in my hatch for over a year now with no problems.
I ran the O2 line through one of the small plugs in the firewall. On my EG there was one just above where the passenger's feet would sit. But it's not easy to find or thread the plug through there.
Old Apr 11, 2007 | 03:43 PM
dem0nk1d's Avatar
until some idiot comes by in the night stealing your ****... make it removable, so you can take it with you... it's the only sane advice I got for you.
Old Apr 11, 2007 | 06:11 PM
94typeR's Avatar
is the plx simulated narrow band signal as accurate as the stock o2 narrowband signal???
Old Apr 12, 2007 | 10:01 AM
Relic1's Avatar
datalogging my setup shows that it's about the same as any of the graphs that I've seen for O2 voltage output.
But I've never ran both so I can have a true compare.
Ek9.civic
Aug 12, 2010 11:59 AM
NightHawkBlack-R
Feb 16, 2009 10:28 AM
EJ8chu
Jan 20, 2007 12:53 PM
racingant
12
Nov 11, 2005 06:41 PM
Aphrodavid
Dec 15, 2002 04:50 PM
