cap and rotor
I have a '93 Accord and need to change the cap and rotor. Is it just a simple unscrew, pop out the rotor and replace, or do I need to know how to position the rotor at certain position? Also, my antenna is busted or has been busted for a long time...the motor seems to run fine with extending the unbent portion of the antenna...thus, can I just replace the antenna or should I replace the whole assembly?
Thanks much for the help.
R&R the rotor and cap is pretty straight foward, I'm pretty sure only the Civics had the screw holding the rotor on.
For antenna info click up this link;
http://members.troublecodes.ne...a.htm
