Changing head gasket
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gasturbtec »</TD></TR><TR><TD CLASS="quote">i have a 98 gsr. is there a trick or a way to get to the two intake manifold bolts that are on the bottom of the manifold? any tips or advice on changing head gasket would be great.</TD></TR></TABLE>
Any trick? not really...either get a good extension and get under the car or stick your hands in behind the engine from up top.
when your ready to put the new head gasket on, inspect the cylinder walls and the cylinder head, look for any cracks/chips in the pistons/wall/valve or combustion chamber.
Pick up a haynes manual if you need more help
