Exhaust Smoke Help!!!
Old Apr 11, 2007 | 12:46 PM
MildWater's Avatar
Default Exhaust Smoke Help!!!
When i accelerate on first from a dead stop and go all the way to the red line, when i start getting up to 5.5-7k rpm my exhaust will start spewing all this smoke. also note that this is doing it from a semi-cold start.
It never did that until i did my y8 intake mani swap on my y7...
Old Apr 11, 2007 | 12:58 PM
97Ej6mike's Avatar
Default Re: Exhaust Smoke Help!!! (MildWater)
Ive seen this before.
Make sure you hooked up all the right coolant lines. I F***ed my motor over in a matter of minutes cause of this awhile back. Going from the downdraft to the standard Y8\Z6 style I/M can be tricky and if you dont know the way manifolds are hooked up, you can really screw up. Look up Diagrams of where coolant lines run. Most likely you confused a coolant with a vaccum and are pouring coolant into your intake. Take care of this right now or else your motor will really suffer.
The Only coolant lines you should have, is one running up behind the Manifold to the Right IAC nipple from the back of the block. The second should go from the Left IAC nipple to the device Underneath the TB ( I forget the name, ive never had issues with it before, lol), and then it runs back to the area by the Dizzy where all the other coolant lines meet.
The issue between Y7 to Y8 Swaps is that the Y7 doenst use some of the same coolant lines, becuase the IAC is all Located on the TB, rather than the back of the manifold.
Make sure those are the only ones running coolant, the others are vaccum.
Old Apr 13, 2007 | 12:33 AM
MildWater's Avatar
if i were to be burning coolant into a vacuum line, id be losing coolant and id have to be refilling the coolant right? i havent noticed a loss in coolant though...
Old Apr 13, 2007 | 12:33 PM
MildWater's Avatar
bump
Old Apr 13, 2007 | 12:56 PM
ddd4114's Avatar
Default Re: (MildWater)
Is the smoke white?
Old Apr 14, 2007 | 04:18 PM
MildWater's Avatar
Default Re: (ddd4114)
ya its a white smoke.
Old Apr 14, 2007 | 04:23 PM
ddd4114's Avatar
It's coolant; do a compression check.
It could be a leaking head gasket, cracked head, or it could be leaking in from the coolant passage in the intake manifold.
Why are you redlining without a fully warm engine?
93civicsedan
Apr 6, 2012 06:32 PM
Steve8091
19
Jan 2, 2010 06:03 PM
JDM00SI
Jan 8, 2007 09:06 AM
Cheez-It
Aug 30, 2006 03:15 PM
