leak in the hatch
Old Apr 11, 2007 | 10:18 AM
streetcartuner's Avatar
Default leak in the hatch
i noticed that their is water in my spare tire compartment and i just want to know what i can do to fix this to stop it because i dont want it rusting their
its a 93 hatchback
Old Apr 11, 2007 | 10:34 AM
kaiba's Avatar
Default Re: leak in the hatch (streetcartuner)
It's probraly coming from the taillight
Old Apr 11, 2007 | 11:07 AM
Default Re: leak in the hatch (kaiba)
i think its more from the seel around the hatch
Old Apr 11, 2007 | 11:19 AM
silentbeatz's Avatar
i have the same problem, but the cargo cover or trunk carpet doesn't get wet. Just a puddle in the spare tire compartment.
Old Apr 12, 2007 | 10:14 AM
Default Re: (silentbeatz)
can neone else help i want to fix this plez neone
Old Apr 12, 2007 | 10:16 AM
EL Vap133's Avatar
Default Re: (streetcartuner)
Strip your hatch interior, sit inside of it and have someone run water on the outside with a waterhose until you find the leak. I did this and fixed my leak the same day!
Old Apr 17, 2007 | 10:15 AM
Default Re: (EL Vap133)
were was ur leak
Old Apr 17, 2007 | 10:27 AM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by streetcartuner &raquo;</TD></TR><TR><TD CLASS="quote">were was ur leak
Where I saw the water coming in through.
Old Apr 17, 2007 | 12:13 PM
thevoice's Avatar
haha i have the same problem 92 dx hatch mine is leaking at the bottom passenger side of the glass
Old Apr 17, 2007 | 12:18 PM
WihaSi's Avatar
Check the seals around your tail lamps, then check your weatherstrip. Most leaks in the rear area come from bad seals around the tail lamps.
Old Apr 17, 2007 | 12:31 PM
DXCIVICHB's Avatar
I found on my 00 ek hatch that it was leaking at the top of the window through the seal on the inside of the window then running down the glass (dont really see it since its also running down on the outside) and into the spare tire area. drip drip..replaced seal around window and all better. also check you hatch seal i replaced it after the fact just to be safe so could be either
tommyboy
Sep 19, 2004 11:45 AM
crx_88_si
10
Feb 23, 2004 04:27 AM
sxecustoms
May 31, 2003 02:30 PM
