Suspension & Brakes Theory, alignment, spring rates....
Suspension related tire wear
Old Apr 11, 2007 | 09:49 AM
MilanoLude's Avatar
Default Suspension related tire wear
I'm not sure if this is possible, but can somone look at the wear of these tires and tell me what kind of suspension problems are contributing to the uneven wear?
The wear I'm talking about is on the inner tread of all the tires, and the rippling on the far right tire in the middle.
I assume the inner tread wear is from negative camber.
Old Apr 11, 2007 | 10:08 AM
gabebauman's Avatar
Default Re: Suspension related tire wear (MilanoLude)
http://heeltoeauto.com/httech/...87420
Old Apr 11, 2007 | 10:23 AM
BlueIntegraBoy's Avatar
Combination of negative toe and negative camber
Old Apr 11, 2007 | 10:29 AM
MilanoLude's Avatar
Default Re: Suspension related tire wear (gabebauman)
Thank you. I read a few articles before that and none of them had real tire pictures, only black and white cartoons.
These are not my tires and the wear is not from my car. I am buying the rims and the tires come with them. I dont want to buy new tires if i don't have to, but I'm not familiar with this kind of wear.
Would these tires last a few months on a vehicle that was properly aligned or would it be a better idea to replace the tires?
Old Apr 11, 2007 | 05:50 PM
TunerN00b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MilanoLude &raquo;</TD></TR><TR><TD CLASS="quote">Thank you. I read a few articles before that and none of them had real tire pictures, only black and white cartoons.
Measure the thinnest section of tread. If there is adequate tread there to last your driving habits (I drive 4.5 miles to work, then home, totalling 9 miles a day. Tires last years for me), then yes, they'll last. Assume you'll get equal wear across the face, and the thinnest section now is the part that will run out first. Any other behavior is a bonus in that scenario.
Old Apr 12, 2007 | 11:22 AM
Officer's Avatar
Default Re: Suspension related tire wear (TunerN00b)
I can barely tell by the pis but it looks on the far right tire that you some cupping on the tires. i have this same problem and i am replacing my shocks as we speak casue of that.
mikbik
13
Aug 28, 2015 03:03 AM
jxhxb
Dec 1, 2008 10:26 AM
jdadams12
May 2, 2006 06:46 AM
AznMTboy
Aug 26, 2005 06:25 AM
Kyles ej1
Jan 8, 2005 04:07 PM
