what kivda wheels are these.. i kinda like them :-)
Reason they won't fit is because that is an Accord - larger bolt pattern than you have.
The only way to get them to fit is to convert to a 4lug suspension from a 96-98 ITR - has the same larger bolt pattern as an Accord/Prelude.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MoonScryer »</TD></TR><TR><TD CLASS="quote">Reason they won't fit is because that is an Accord - larger bolt pattern than you have.
Correct
The only way to get them to fit is to convert to a 4lug suspension from a 96-98 ITR - has the same larger bolt pattern as an Accord/Prelude.</TD></TR></TABLE>
In-correct
Only the 1996 ITR had the 4 x 114.3 lug patter. The 1997 and up ITR's were 5 lug, 5 X 114.3, which happens to be Ford and Toyota's as well as many other companies bolt pattern.
Not tryin to be a jerk, just tryin to keep the info correct. God knows there's enough mis-information infecting this website already.
Correct
In-correct
http://www.hondamarketplace.co...36504
https://honda-tech.com/zerothread?id=1941091
http://www.hondamarketplace.co...40956
https://honda-tech.com/zerothread?id=1710117
Got those real quick.
Modified by mac_24_seven at 1:09 PM 4/11/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nevets »</TD></TR><TR><TD CLASS="quote">The 97 USDM Type R had 4x114</TD></TR></TABLE>
NO, all Type R's in the US came 5x114 not 4x114
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM se-R »</TD></TR><TR><TD CLASS="quote">NO, all Type R's in the US came 5x114 not 4x114</TD></TR></TABLE> your stupid
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by youknowimwhite »</TD></TR><TR><TD CLASS="quote"> you're stupid</TD></TR></TABLE>
NO, stfu, 96 ITRs came with the 4 lug, then the REST were 5 lug.
thanks you guy for all the help.. kinda sucks to know i can put'em on the teggy.. but hey im perfectly happy with my blades :-) does the 99 prelude and the type r have the same bolt patterns or no?"?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wytechoppin »</TD></TR><TR><TD CLASS="quote">thanks you guy for all the help.. kinda sucks to know i can put'em on the teggy.. but hey im perfectly happy with my blades :-) does the 99 prelude and the type r have the same bolt patterns or no?"? </TD></TR></TABLE>
Yes. 96 and 97 ITRs in JAPAN have 4x114.3. 98 and up have 5x114.3. ALL USDM ITRs have 5x114.3. 97-01 Preludes are all 5x114.3 as well. As are S2000s.
96Civic_Coupe
Feb 24, 2007 06:11 PM
