Painting Car: Help
Old Apr 11, 2007 | 09:14 AM
carlosd68's Avatar
Default Painting Car: Help
So this summer I plan on painting the outside of my eg just to try and learn. I just wanted to get some tips from those who are experts or have done this before. The car only has like 2 dents...
1) What kind of bando should I buy to fill this?? How exactly do you put it on?
2) When sanding the car down, what sandpaper grade should i be using? Dry Sand? or wet sand?
3) I hear that when mixing the paint u use reducer, paint and hardener for the whole body except for bumpers (to give it some flexibility)
4) Is a coat of primer really necessary before paint??
Any tips to get me started....I am familiar with the procedure for the most part, but I guess I want to know the things to avoid doing to make the job easier.
Any help is appreciated
Old Apr 12, 2007 | 06:56 AM
carlosd68's Avatar
Default Re: Painting Car: Help (carlosd68)
Anyone?
I read some stuff that said the best way to start is by using wet/ dry 400 grade sand paper.....
then move on to primer the car and sand that down with 600 grade
wash off the car, make sure all the grease is done
do all the masking for parts that dont need to be painted
i couldnt find much on what bondo to use in case the ding puller dont work
Old Apr 12, 2007 | 07:04 AM
BLANCOh22a4's Avatar
Umm dont believe everything that you hear, because have of the things you jus listed arent true. Yes obviously you would want to fix the dents use minimal bondo...depending on where the dents are and how big they are. If they are big then try and popping them out, and then smooth it out with a coat of plastic. Make sure you then sand it with 80 grit and 220 grit. Primer the whole car and sand wetsand with 400. (Make sure you use 2-3 good coats or primer in between.) Then pick a color and then use a base coat, clear coat , and preferably chromabase.
Old Apr 12, 2007 | 09:01 AM
carlosd68's Avatar
Default Re: Painting Car: Help (BLANCOh22a4)
thanks for the help....when painting, how many base coats are recommended? how much time in between them?? how about for clear coats??
Old Apr 12, 2007 | 05:27 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carlosd68 &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the help....when painting, how many base coats are recommended? how much time in between them?? how about for clear coats??</TD></TR></TABLE>
usually three base coats, depending on the weather (65-70 ideally) about 15-20 minutes...and you wanna do about 2 clear coats
Old Apr 12, 2007 | 05:35 PM
Markland Photo's Avatar
if you search for more results, i belive theres a 100 page thread on plenty of people who can help you out further
Old Apr 12, 2007 | 08:54 PM
2'z kuztoms's Avatar
From: Streets of Sacramento...But now living in So Cal, usa
if you need materials pm me. i have some fs
Old Apr 12, 2007 | 09:08 PM
SneezinCD5's Avatar
Painted my car for the first time back about 2 1/2 years ago. Never painted before and was taking an autobody class. Came out VERY WELL! Best thing to do is to get a book on autobody. Since then I have painted many other cars and getting better and better everytime.
Here is my Accord the first time I sprayed it.
Also you don't have to primer the whole car you can just use a sealer like I did.
Second time:
By the way I use PPG products. Lays down well and has a hell of a shine
Old Apr 12, 2007 | 09:16 PM
B and B's Avatar
Loved
Community Favorite
This site has alot of pros on there and they like to help if your respectful.....
http://www.autobody101.com/forums/
Oh...and Evercoat is what I've heard is the best filler.
Do not use Bondo brand.
Old Apr 13, 2007 | 02:18 AM
JCL's Avatar
JCL
alright, i didnt want to make another thread cuz its just a quick question. im guna have an auto body shop paint the exterior of a dc2. but i want to sand it down my self. from what i have heard you would go from 60-80-120-180-220 and then wet + dry with 1000grit or w/e after the primer coat. is that true? reasoning because i have a buddy that is in the auto body shop class in school and i dont want to dish out 2gs to get the car painted. i would try and paint it my self but i donth ave the materials and i would really only use it this time.
thanks.
Old Apr 13, 2007 | 07:05 AM
carlosd68's Avatar
Default Re: (JCL)
can anyone answer this question?
Old Apr 13, 2007 | 07:37 AM
carlosd68's Avatar
Default Re: (carlosd68)
everyone VOTE YES here
https://honda-tech.com/zero...age=2
Old Apr 14, 2007 | 12:23 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carlosd68 &raquo;</TD></TR><TR><TD CLASS="quote">So this summer I plan on painting the outside of my eg just to try and learn. I just wanted to get some tips from those who are experts or have done this before. The car only has like 2 dents...
this is what you need
Old Apr 14, 2007 | 01:55 AM
slowpokecivic's Avatar
Default Re: Painting Car: Help (2'z kuztoms)
i have a fiberglass front bumper and there are cracks in it...
actually more like a big chunk cracked off...would bondo from autozone or kragen be okay to fill it?
Old Apr 14, 2007 | 10:57 PM
SneezinCD5's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2’z kuztoms &raquo;</TD></TR><TR><TD CLASS="quote">
Looks exactly like mine! Good to see we both you PPG Is that some DCU2021 I see?
Old Apr 16, 2007 | 11:27 AM
carlosd68's Avatar
Default Re: Painting Car: Help (SneezinCD5)
SneezinCD5 u did a real clean job with the accord both times....hopefully mine comes out close to that........Does anyone here have hook ups with paint??? PPG or Dupont ??? let me know Thanks for the help everyone
Old Apr 19, 2007 | 07:57 PM
SneezinCD5's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carlosd68 &raquo;</TD></TR><TR><TD CLASS="quote">SneezinCD5 u did a real clean job with the accord both times....hopefully mine comes out close to that........Does anyone here have hook ups with paint??? PPG or Dupont ??? let me know Thanks for the help everyone</TD></TR></TABLE>
I get a really good deal with PPG. I am actually going to pick some up back in my hometown Savannah next week. They give me great deals on paint! Let me know if you need some paint.
And thanks for the comment. Goodluck with yours.
Old Apr 19, 2007 | 08:03 PM
kiddcarbuff's Avatar
get you some of these!
and one of these!
the cabinet the guns are on has 2 more sata guns in it and is filled w/ dupont stuff. i have another cabinet for detailing supplies and tapes. and a 4 ft paper roll on teh ceiling. lol dad is a painter, so he has 3 times the amout of **** at work hah
Old Apr 20, 2007 | 01:31 AM
JCL's Avatar
JCL
how would one go abouts removing the roof or would you just make everything off?
GroundZer0
Mar 8, 2010 10:30 AM
SlAmmmmmed-DB8
Paint and Body
Jul 5, 2009 03:14 PM
latino honda
Paint and Body
Nov 2, 2007 10:05 AM
Smallpox33
Paint and Body
May 20, 2007 09:03 AM
turbotime
Jun 8, 2004 09:45 PM
