starting issue
i have no clue whats wrong with it! drove it all morning parked it came back out after a short rstroom breakcar wont start engine rotates but will not start. yes i am getting sparks yes my timing is correct...after i let it sit for a few hours it started right up....have no idea where to start looking.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dylokjai »</TD></TR><TR><TD CLASS="quote">all 4 spark plug smells like GAS!</TD></TR></TABLE>
You can't use that method to test that. They have to be WET. Anything part that has gas going near it, will smell like gas.
I bet it's your main relay. Swap it out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89_Mangina_SI »</TD></TR><TR><TD CLASS="quote">check for fuel... sounds like it could be ur main relay going out</TD></TR></TABLE>
x2, can you hear the fuel pump priming before you start the vehicle?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dylokjai »</TD></TR><TR><TD CLASS="quote">what should be the correct ignition timing 16? </TD></TR></TABLE>
Yes, 16 BDTC.
Yes, 16 BDTC.
DA6_toojy
Oct 12, 2005 06:30 PM
