ATTN: Omnipower Owners. Ride height problem!
Old Apr 10, 2007 | 10:59 PM
hazard_one's Avatar
Default ATTN: Omnipower Owners. Ride height problem!
I just recieved my omnipowers and installed them today! i love the ride but is anyone running omnipowers on the lowest setting? ride now i have about 10 threads left with a finger gap left and i want to tuck my tires.
Old Apr 11, 2007 | 12:07 AM
rickeg6's Avatar
damn that low bro........
Old Apr 11, 2007 | 12:13 AM
spoon_ek9's Avatar
Default Re: ATTN: Omnipower Owners. Ride height problem! (hazard_one)
just make sure u get enough stroke of the shock, or else life will be shorten.
Old Apr 11, 2007 | 01:28 AM
hazard_one's Avatar
Default Re: ATTN: Omnipower Owners. Ride height problem! (spoon_ek9)
yeah im kinda disappointed on the ride height. ill drop it to the lowest setting tomorrow to see if it will close the gap. i dont think the stroke of the shock matters since its full coilovers (correct me if im wrong) im actually just shortening the length of the whole shock itself
Old Apr 11, 2007 | 01:32 AM
spork motorsports's Avatar
* B A N N E D *
no you're not shortneing the shock its self, you re putting less tension on the spring yes it will be lower, and yes shock travel does matter
Old Apr 11, 2007 | 02:05 AM
hazard_one's Avatar
Default Re: ATTN: Omnipower Owners. Ride height problem! (spork motorsports)
i think youre going to have to explain that one to me. Omnipowers along with alot of newer coilovers lower the ride height by adjusting the lower collars as opposed to slip-ons that lower the springs. The springs arnt even touched if change the settings.
the only think i should worry about is my car being too low and my wheel rubbing on the A arms.
but anyways. ANY OMNIPOWER OWNERS care to shed light on my situation?
Old Apr 11, 2007 | 02:12 AM
hazard_one's Avatar
Probably the best way is to post your ride on omnis. Did you also preload the new tilyte coilovers?
Old Apr 11, 2007 | 02:14 AM
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hazard_one &raquo;</TD></TR><TR><TD CLASS="quote">
the only think i should worry about is my car being too low and my wheel rubbing on the A arms. </TD></TR></TABLE>
elaborate you know what an a arm is?
Old Apr 11, 2007 | 02:17 AM
* B A N N E D *
i dont reallt think you know what you're talking about
you adjust rid height by turining 2 locking rings then loking them meaning indeed the spring comes lower
omni power adustable suspension kit
Old Apr 11, 2007 | 02:18 AM
Chim Chim's Avatar
A close friend of mine had tilytes on his del sol. The only way he was able to get zero fender gap/slight tuck in the front was to take out some pre-load. Needless to say, it was a bumpy ride...
Old Apr 11, 2007 | 02:21 AM
hazard_one's Avatar
part 6,7 . ive had friends rub on that before. are at least totally messed them up from being slammed.
no actually you dont lower with the 2 locking rings. the 2 locking rings are there to adjust preload. you lower it by moving the locking ring above the collar UP along with the collars (bottom part of the coilover)
Old Apr 11, 2007 | 02:24 AM
hazard_one's Avatar
Default Re: ATTN: Omnipower Owners. Ride height problem! (Chim Chim)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chim Chim &raquo;</TD></TR><TR><TD CLASS="quote">A close friend of mine had tilytes on his del sol. The only way he was able to get zero fender gap/slight tuck in the front was to take out some pre-load. Needless to say, it was a bumpy ride...</TD></TR></TABLE>
damn thats what im afraid of . anyone got an EG or an EJ1?
Old Apr 11, 2007 | 09:47 AM
Civichatch2k's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spork motorsports &raquo;</TD></TR><TR><TD CLASS="quote">i dont reallt think you know what you're talking about
Incorrect, according to omnipower the ride height is adjusted by the lower colloar. The spring sets the pre-load on the strut it self. This adjustmet lowers the car without taking away stroke.
Old Apr 11, 2007 | 09:48 AM
The ride height is seperate from the strok of the struts.
if you change the setting of the spring then you will change the preload.
Just follow the instructions for how to set them up and you will be golden.
Old Apr 11, 2007 | 06:24 PM
hazard_one's Avatar
Default Re: (Civichatch2k)
so i put the coilovers to the lowest setting today... VERY disappointed. i cant even tuck it
Old Apr 11, 2007 | 06:46 PM
bbbleondacomeup's Avatar
Default Re: (hazard_one)
just wondering y u want to tuck it??? cause it looks cool???? handlin is worse when ur tires r tucked compared to moderatly dropped..... it u want real performance u leave the drop... u wanna be ricer cool then slam it
Old Apr 11, 2007 | 07:04 PM
spoon_ek9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hazard_one &raquo;</TD></TR><TR><TD CLASS="quote">so i put the coilovers to the lowest setting today... VERY disappointed. i cant even tuck it </TD></TR></TABLE>
coz the car is not design to have the tire tuck. with that height, your roll center is lower than the ground and the suspension is not working well under that condition. but if u are after the look, it is ok to do it.
Old Apr 11, 2007 | 08:04 PM
mister_ej1's Avatar
Default Re: (spoon_ek9)
im bout to order some omnis for my ej...ill tell u how they turn out when i get em done
Old Apr 11, 2007 | 09:31 PM
akmi_1's Avatar
Default Re: (mister_ej1)
i have a 98 coupe...i bought the omni fullcoilovers about 8 months ago...i threw them on my car and followed the instructions ...this was bouncy as *expletive*...so i pre-loaded them by compressing the spring with the locking rings and i also shortened the actual length of the FULLCOILOVER to the shortest possible...this made my car ride like a CHAMP...but still it wasn't that low...i had a gap of about 1" front and 2" rear...after 6k on the setup the gaps disappeared and now im riding low with no gap so basically u need to BREAK-IN your setup...this was the best investment i have ever made...
Old Apr 11, 2007 | 10:04 PM
kenny24's Avatar
Default Re: (akmi_1)
how do u preload??
Old Apr 11, 2007 | 10:10 PM
spoon_ek9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by akmi_1 &raquo;</TD></TR><TR><TD CLASS="quote">i have a 98 coupe...i bought the omni fullcoilovers about 8 months ago...i threw them on my car and followed the instructions ...this was bouncy as *expletive*...so i pre-loaded them by compressing the spring with the locking rings and i also shortened the actual length of the FULLCOILOVER to the shortest possible...this made my car ride like a CHAMP...but still it wasn't that low...i had a gap of about 1" front and 2" rear...after 6k on the setup the gaps disappeared and now im riding low with no gap so basically u need to BREAK-IN your setup...this was the best investment i have ever made... </TD></TR></TABLE>
u better check to see if the spring got shorten. u will be surprised.
Old Apr 11, 2007 | 10:11 PM
akmi_1's Avatar
Default Re: (kenny24)
twist the spring locking rings towards the top so u are actually creating tension on the spring...
Old Apr 11, 2007 | 10:26 PM
hazard_one's Avatar
actually its starting to tuck. i guess it has to settle.
dont get me wrong, unless i plan to autox this sucker then i would raise it, but its a daily driver so YES i DO want to look cool and a ricer.
Old Apr 12, 2007 | 03:14 AM
Jay_Sensing's Avatar
I know see what 1800 posts in 6 months will get you, a big head and no knowledge.
Omni's are preload/height adjustable and both adjustments are seperate so why don't you stop posting random idiocy like you do nightly and take some time and learn about what you are bumping your gums about.
To the OP, they will have to settle man. I have used Omni's on all my Hondas and love them. Once you get them broken in, you won't want any other coilover for less than 1400 bucks.
Old Apr 12, 2007 | 01:35 PM
hazard_one's Avatar
Default Re: ATTN: Omnipower Owners. Ride height problem! (Jay_Sensing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jay_Sensing &raquo;</TD></TR><TR><TD CLASS="quote">I know see what 1800 posts in 6 months will get you, a big head and no knowledge.
To the OP, they will have to settle man. I have used Omni's on all my Hondas and love them. Once you get them broken in, you won't want any other coilover for less than 1400 bucks. </TD></TR></TABLE>
haha. thanks i hope youre right. its not looking TOO bad right now...
Autobotz8
Mar 2, 2010 10:14 PM
maxogsr
Suspension & Brakes
Apr 24, 2009 01:58 AM
acrophobia
Suspension & Brakes
11
Jul 22, 2008 10:37 AM
street_ride14
Suspension & Brakes
Mar 15, 2007 10:25 AM
Ti3d in
Suspension & Brakes
12
Jan 24, 2005 06:26 AM
