fender liners?
i was just wondering and i have searched. is it a bad idea to drive without your front fender liners? when im slammed turning radius sucks. would this help or not a good idea?
Cool Cool Island Breezes. BOY-EE
it would help your rubbing. BUTTTTT. I would leave them in because:
Wont be able to use CAI because water will splash errwhurr.
Your doorjambs will be filled with CRAP that your car throws up into the wheel wells. The fender liners keep all that stuff under the fenders.
It looks dumb. You see a bunch of exposed stuff
I never had a problem
What rim/tire size are you on?
hmm.. good points.. thanks guys i guess i have to sacrifice turning for being slammed.
but im rolling on 205/50/15 on blades.. when i needa change tires i would go thinner i guess. would 195/45/15 be better?
I took mine off and regret ever doing so. I put a aem v2 on and had to take it off withiin days because the filter was so filthy, wasn't worth cleaning every other day, not to mention the chances for hydrolock.
I ended up just raising my car a bit and am looking for new fender liners lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TastyDragon »</TD></TR><TR><TD CLASS="quote">hmm.. good points.. thanks guys i guess i have to sacrifice turning for being slammed.
but im rolling on 205/50/15 on blades.. when i needa change tires i would go thinner i guess. would 195/45/15 be better?</TD></TR></TABLE>
You'll never find that size(195/45/15). The size you're probably looking for to go smaller would be a 195-50-15. I was rolling on 205-50-15 on that EK that is pictured above. They were (obviously) stock CTR wheels....so same size and width as your GSR wheels. Maybe integras have smaller wheel wells or something. BTW your stock size on a DC would be 195-55-15. The 205/50/15 is actually smaller than the 195/55/15 in diameter. The width is 10mm wider. So going down to a 195/50/15 would look kinda....you know....homo-erotic.
but im rolling on 205/50/15 on blades.. when i needa change tires i would go thinner i guess. would 195/45/15 be better?</TD></TR></TABLE>You'll never find that size(195/45/15). The size you're probably looking for to go smaller would be a 195-50-15. I was rolling on 205-50-15 on that EK that is pictured above. They were (obviously) stock CTR wheels....so same size and width as your GSR wheels. Maybe integras have smaller wheel wells or something. BTW your stock size on a DC would be 195-55-15. The 205/50/15 is actually smaller than the 195/55/15 in diameter. The width is 10mm wider. So going down to a 195/50/15 would look kinda....you know....homo-erotic.
From: new jersey home of wanna be's posers claimers ricers biters and where everyone fakes the funk
up to you..doesnt make it better or worse to have them...but umight collect dirt or rocks in the door jam towards the fender.
yeaaahh..its up to you..depeds on weeather or your enviroment/conditions but if you can keep em in there without any rubbing problemsjust keep em!
gnozahs
Jun 19, 2014 10:50 PM
but only if it's in good condition
