Do 91 Dx civics come with sway bars in the front?
i havent had a chance to check yet, but is it possible to mount a front si sway bar to an std? i know the front lower control arms have the holes for it, but does the sub frame have it?
you just need the endlinks and U brackets and bolts. the subframe is already prepped for it.
this is just for the front.
DX and Si front swaybars are the same. sedan swaybars are 1mm thicker at 19mm.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote">you just need the endlinks and U brackets and bolts. the subframe is already prepped for it.
this is just for the front.</TD></TR></TABLE>
Yup. Put my old CRX HF swaybar on the new Std. Hatch last month. Quick bolt up.
DX and Si front swaybars are the same. sedan swaybars are 1mm thicker at 19mm.</TD></TR></TABLE>
thanks, i thought i heard somewhere(dont remember where) that the subframe did have the holes, but no threads for the bolts to secure the U brackets in place.
The nuts for the U-Brackets are definitely in there for the front. Now they aren't there in the rear though. Hope that you can find the website you saw the misinformation so you can correct them.
tooslohatch
17
Jul 11, 2013 09:50 AM
