DPFI from hell! have a question.
Old Apr 10, 2007 | 08:29 PM
MR.johnson's Avatar
Default DPFI from hell! have a question.
i just swaped a A6 into a DPFI four door with a shaved .020 or .20 whatever it is and it has no power from idle to about 6000 and i was wondering if it would take that much more fuel to make it run correctly with higher compression?
he plans on doing a tuned MPFi setup soon but we want something to beat on right now.
yes i know single slammers are junk, so dont say "why the hell would you do that"
thanks.
Old Apr 10, 2007 | 08:43 PM
Natural Aspirations's Avatar
Possible cam timing issues
Old Apr 11, 2007 | 04:43 AM
MR.johnson's Avatar
Default Re: (Natural Aspirations)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Natural Aspirations &raquo;</TD></TR><TR><TD CLASS="quote">Possible cam timing issues</TD></TR></TABLE>
ok will check that.
Old Apr 11, 2007 | 01:52 PM
MR.johnson's Avatar
Default Re: (MR.johnson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MR.johnson &raquo;</TD></TR><TR><TD CLASS="quote">
ok will check that.</TD></TR></TABLE>
just did and now it seems to be running out of fuel above 4500 or so.
Old Apr 11, 2007 | 01:57 PM
honda_ef9's Avatar
dpfi to mpfi wiring issue check you flashes on the ecu and get back to us
Old Apr 11, 2007 | 02:00 PM
MR.johnson's Avatar
Default Re: (honda_ef9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda_ef9 &raquo;</TD></TR><TR><TD CLASS="quote">dpfi to mpfi wiring issue check you flashes on the ecu and get back to us</TD></TR></TABLE>
no its still a DPFI. no codes.
Old Apr 11, 2007 | 02:11 PM
honda_ef9's Avatar
oh lol i see id say it prolly needs more fuel but idunno
Old Apr 11, 2007 | 02:21 PM
MR.johnson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda_ef9 &raquo;</TD></TR><TR><TD CLASS="quote">oh lol i see id say it prolly needs more fuel but idunno</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MR.johnson &raquo;</TD></TR><TR><TD CLASS="quote">
i think thats whati just said. thanks tho.
Old Apr 11, 2007 | 02:32 PM
spun Vtec's Avatar
Default Re: DPFI from hell! have a question. (MR.johnson)
something's wrong. Not just the fuel issue.
If the a6 is getting fed the same map as the dx It should have at least the same power as the dx. It would be lean throught the power band but mostly up top.
It should run almost the same (not any slower) as the dx with the dpfi it will just be lean.
Fuel is not your issue. (I wouldnt reccomend running it like that for a long time)
Old Apr 11, 2007 | 03:10 PM
MR.johnson's Avatar
Default Re: DPFI from hell! have a question. (spun Vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spun Vtec &raquo;</TD></TR><TR><TD CLASS="quote">something's wrong. Not just the fuel issue.
Fuel is not your issue. (I wouldnt reccomend running it like that for a long time)</TD></TR></TABLE>
it does have a shaved head a nd a 2 layed head gasket.
so i dono.
Old Apr 11, 2007 | 05:39 PM
spun Vtec's Avatar
so i dono.</TD></TR></TABLE>
You dont know what???
That has nothing to do with your problem. How much was it shaved? It will just bump up your compression.... not make the car run worse than a dx.
Old Apr 11, 2007 | 05:40 PM
MR.johnson's Avatar
That has nothing to do with your problem. How much was it shaved? It will just bump up your compression.... not make the car run worse than a dx.</TD></TR></TABLE>
more compression means more fuel. running lean wound make it slower.
ALLmotorTYPES
24
Jul 7, 2007 08:31 AM
turnsignalandy
Feb 28, 2007 10:02 AM
bboyoxygen
Jul 25, 2006 08:51 AM
bb6h22
Oct 11, 2004 10:28 PM
DRAGLS
Jan 11, 2004 05:19 PM
