Stainless Steel or Ceramic Header?
Old Apr 10, 2007 | 08:26 PM
drew338's Avatar
Default Stainless Steel or Ceramic Header?
what one is better to get? Thanks
Old Apr 10, 2007 | 09:00 PM
petern101's Avatar
Default Re: Stainless Steel or Ceramic Header? (drew338)
umm how about a better question?
it usually doesn't matter the material, it matters how the header was designed.
why don't you look at the faqs and search
Old Apr 11, 2007 | 06:33 AM
smeck's Avatar
here's some more info....
a ceramic (or coated) header gives off less heat, a st one will most likely be more durable.
Old Apr 11, 2007 | 11:57 AM
drew338's Avatar
Default Re: Stainless Steel or Ceramic Header? (petern101)
the question is just fine im sorry if its not good enough for you but it is for the person under you. why are people smart ***'s on here? lol i did search
Old Apr 11, 2007 | 12:46 PM
Speedra500's Avatar
SS is probably worth the extra money. If you are concerned about the extra heat you should be able to wrap a SS header which would be significantly less heat in your engine bay than a ceramic coated header
Old Apr 11, 2007 | 04:38 PM
drew338's Avatar
Default Re: Stainless Steel or Ceramic Header? (Speedra500)
Thanks thats what i wanted to know
ANDREW D
Oct 15, 2004 07:03 PM
slowone
Sep 28, 2003 08:53 PM
soopafly828
Apr 30, 2003 03:48 PM
RCautoworks
Mar 3, 2003 05:03 PM
Blue Liquid
Mar 14, 2002 04:11 AM
