What alternator will work?
Old May 27, 2002 | 04:48 PM
CHRIS 1.8's Avatar
Default What alternator will work?
I have a JDM B16a and my alternator is bad. Can I buy a alternator from Kragen's or something? What do I ask for since I don't have a stock motor? Please help! Thanks.
Old May 27, 2002 | 06:08 PM
Greg L's Avatar
Default Re: What alternator will work? (only JDM)
try one for a 99-00 Civic Si
Old May 27, 2002 | 06:36 PM
CHRIS 1.8's Avatar
Default Re: What alternator will work? (WannaBFast)
Ok, cool.
Old May 27, 2002 | 06:38 PM
fowler!'s Avatar
the plugs might be different..
going into a 90 civic, right?
check in the EF/CRX forum.
Old May 27, 2002 | 06:40 PM
markpaco's Avatar
If you have a 1st gen B16A, you can use the alt from a 90-93 Integra. If you get the 99-00 B-series it will not plug in.
Old May 27, 2002 | 06:50 PM
jdmjunkie's Avatar
Default Re: What alternator will work? (markpaco)
he's right there is a difference in pre OBD, OBDI, and OBDII
Old May 27, 2002 | 06:51 PM
CHRIS 1.8's Avatar
Yea, I have a 1st generation B16a. What model 90-93 Integra alternator can I use? My friend said I can either ask for a Del Sol VTEC or 2000 Si...
Old May 27, 2002 | 06:53 PM
CHRIS 1.8's Avatar
Default Re: What alternator will work? (jdmjunkie)
I'm not talking about a DISTRIBUTOR...I'm talking about a ALTERNATOR. Just wanted to point that out. Heh.
Old May 27, 2002 | 06:55 PM
Plan B's Avatar
All 90-93 integra alternators are the same. In fact! We once used a 1st gen b16 alternator on a zc sohc engine. So maybe even a crx or civic alternator from the same year will work. Check your alternator from your old motor.
Lates!
Sanj
Feb 19, 2007 04:21 PM
skiracer8148
Jan 23, 2006 01:42 AM
DaneishsleepeR
Nov 26, 2004 12:24 PM
CHRIS 1.8
May 28, 2002 09:00 PM
