Finally got right (no 56k_pics)
Old Apr 10, 2007 | 07:14 PM
vtec8804's Avatar
* B A N N E D *
Default Finally got right (no 56k_pics)
So i finally got my car back to how she was before, but better. i recently purchased my 98 gsr with 120,000miles. at 125k, she went downhill and spun a bearing in the lower end.
i was left with the damage done by the kid before me, so i purchased a new gsr motor with 51k on it and had it swapped out.
here are some pics i just want to see what u guys think. im going to get a lip, need some help deciding on a cf front lip or just a plain white type r one. what u guys think? i could prob go either way, on the lip.
Old Apr 10, 2007 | 07:28 PM
Insomniac.TheMan's Avatar
Tech? This is more suitable for A/C.
I would say white R lip.
Check your upper dizzy bolt
Old Apr 10, 2007 | 07:31 PM
JDM-EJ1's Avatar
Default Re: (Insomniac.TheMan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Insomniac.TheMan &raquo;</TD></TR><TR><TD CLASS="quote">Tech? This is more suitable for A/C.
Check your upper dizzy bolt </TD></TR></TABLE>
Yes, this belongs in AC. And instead of checking the bolt, he should put one in there.
Old Apr 10, 2007 | 07:59 PM
stumpyf4's Avatar
Default Re: Finally got right (vtec8804)
Missing a bolt on the dizzy.
Old Apr 10, 2007 | 08:22 PM
kinick313's Avatar
Clean man! I don't dig the panda look, personally I'd get that hood painted friggin lickety split! but damn dude... thing looks friggin spickety span. Is that the original paint?
Old Apr 10, 2007 | 09:40 PM
deadline's Avatar
i'd say get a type R wing and you'll be set.....
Old Apr 10, 2007 | 11:37 PM
leeminho86's Avatar
Wow really clean man Is that a cf hood or black? I personally like black on white, and either lip would look good, hell why not get both and keep a spare
Old Apr 11, 2007 | 04:12 AM
bkmc24's Avatar
Default Re: (JDM-EJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ1 &raquo;</TD></TR><TR><TD CLASS="quote">
Yes, this belongs in AC. And instead of checking the bolt, he should put one in there.</TD></TR></TABLE>
Where is the dizzy, and wtf is it? i kind of know what it is, but not really, someone elxplain plz!
Old Apr 11, 2007 | 04:13 AM
bkmc24's Avatar
Default Re: (bkmc24)
Oh and what wheels are those, they are amazing!!
Old Apr 11, 2007 | 04:23 AM
mac_24_seven's Avatar
Old Apr 11, 2007 | 05:32 AM
Tonyl507's Avatar
Default Re: (mac_24_seven)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bkmc24 &raquo;</TD></TR><TR><TD CLASS="quote">
Where is the dizzy, and wtf is it? i kind of know what it is, but not really, someone elxplain plz!</TD></TR></TABLE>
You <U>may </U>want to put a bolt here... Otherwise very nice - Go with the white lip
EDIT: yeah id like to know what wheels thoes are too... veeery niice
Modified by Tonyl507 at 6:42 AM 4/11/2007
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec8804 &raquo;</TD></TR><TR><TD CLASS="quote">So i finally got my car back to how she was before, but better. i recently purchased my 98 gsr with 120,000miles. at 125k, she went downhill and spun a bearing in the lower end.
This may sound liek a noob question... but how exactly do ou spin a bearing? What does it sound like and what does it exactly do?
Old Apr 11, 2007 | 07:09 AM
vtec8804's Avatar
* B A N N E D *
they are CE28 replicas made by kyowa racing. best part about it is they are like 500 for new 17's. these wheels are like 2 years old and still mint.
thanks for the dizzy bolt.
im by no means a master mechanic so if ur looking for some indepth answer idk. but my mechanic who i trust, bbc he worked on all my cars and family and neighbors said its from running this car low on oil, and not changine it, kno htat wasent me bc i changed it every 2500 and thats only twice since i had it..
i was left with the kid before me his damage
the hood is CF whats why im considering the cf lip
well i put it in tech, bc i posted in tech about my problem b4 and now that i got the car running again i wanted everyone before who posted to see it. so
edit- when spun my lower main bearing it sounded like nails being turned over in the engine... nottt sooo nice
Old Apr 11, 2007 | 07:23 AM
S2KILLA's Avatar
Default Re: (vtec8804)
so when you spin your bearing how much damage does this do???
Old Apr 11, 2007 | 08:07 AM
vtec8804's Avatar
* B A N N E D *
from what i understand.-
it takes the lower end, other then that im not sure of what acutally happens. ive been reading a little trying to find out what effects it does have, but nothing to this effect yet.
reason motor was basically totaled is bc it would take as much labor to put the parts in as the motor was worth, and i couldent do it myself so i was **** out of luck.
Old Apr 11, 2007 | 08:15 AM
ls19integra95's Avatar
i have spun a bearing many times on all my cars... when one spins you would know it because you will start hearing this really loud tapping and eventually benging in the bottom end of your car and sometimes it even tries to stall out... one time it destroyed my crank and a rod... another time it totally destroyed the whole bottom end, i needed pistons, sleeves, crank, rod, and everything was completely filled with metal shavings...
Old Apr 11, 2007 | 08:24 AM
S2KILLA's Avatar
Default Re: (ls19integra95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ls19integra95 &raquo;</TD></TR><TR><TD CLASS="quote">i have spun a bearing many times on all my cars... when one spins you would know it because you will start hearing this really loud tapping and eventually benging in the bottom end of your car and sometimes it even tries to stall out... one time it destroyed my crank and a rod... another time it totally destroyed the whole bottom end, i needed pistons, sleeves, crank, rod, and everything was completely filled with metal shavings...</TD></TR></TABLE>
are there any symptoms of a bearing going bad that you can change it before destruction happens??? will it set off a CEL?
Old Apr 11, 2007 | 08:31 AM
vtec8804's Avatar
* B A N N E D *
i got no CEL's, mine was at about the stage where everything goes,... i was told change ur oil, make sure ur running the right level.. main cause of this problem
Old Apr 11, 2007 | 09:33 AM
S2KILLA's Avatar
sorry to thread jack... actually im going to start my own thread now cuz im pretty scared taht this might happen to me... thanks for your help so far
Old Apr 11, 2007 | 05:59 PM
vtec8804's Avatar
* B A N N E D *
so really everyone thinks white, bc i was starting to lead towards cf... i mean i know its my car and do what u want but still..
i can get both for about the same price under 230
Old Apr 11, 2007 | 06:55 PM
Drew87029's Avatar
I would go cf, to go wit the hood but it would look even better if your wheels were black imho.
Old Apr 11, 2007 | 07:12 PM
fergy016's Avatar
Default Re: (grlfromlastnight)
cf will show scratches more then a painted lip that can be repainted. A carbon fiber lip will crack like fiberglass.
Old Apr 12, 2007 | 03:49 AM
blackKready's Avatar
Default Re: (fergy016)
theres little tabs on the bearings that hold them in place in thier journals. the bearings dont turn , they stay in one spot , the crank turns in them. if theres an oiling problem or high revs(usually go hand in hand) , too much friction happens between the crank and the bearing , and the crank actually grips the bearing enough to spin it in its journal. when this happens , it blocks the oil supply drastically , or all together. than the crank will grind away the bearing till its literally gone. and your left with the crank rod journal riding in the big end of ths piston rod with no bearings at all. since theres no bearing , theres lots of clearance between crank and rod journals where bearing used to fill the gap , which is where you get knock. and once a honda engine develops a knock like this , you have minutes , lol.
Old Apr 12, 2007 | 04:32 AM
vtec8804's Avatar
* B A N N E D *
ya thats a good description, i was reading an article that was written in that direction
what do u guys think thou if i get a CF lip, i know how to drive with a low car i wont scrape it, and if it gets chipped worse comes to worse i could paint it right?
i found one in mint cond. for 250 shipped
thanks for all the comments guys
Old Apr 12, 2007 | 11:24 AM
shillsdc2's Avatar
cf lip will get scratch and break sooner or later ...... the other u can just repainted
