Megan header collector Mod
Old Apr 10, 2007 | 07:00 PM
LukieLuc's Avatar
Default Megan header collector Mod
Do you guys think that i should go to my local exhaust shop for them to make and weld a new 2.5 inch collector, or should i buy the pre made collectors on ebay and have them weld it on?
http://cgi.ebay.com/ebaymotors...ZWDVW
That is the link to ebay pre made collector
Old Apr 10, 2007 | 07:18 PM
LukieLuc's Avatar
Default Re: Megan header collector Mod (LukieLuc)
Old Apr 10, 2007 | 08:33 PM
InvaderTrax's Avatar
Well, first off, most exhaust shops don't cary 2.5" flex pipes. You may be able to get them to put a donut gasket style flange on like on a Civic, which would work just as well, if not better. That being said, my quotes ranged from $100 to $200 for labor
Old Apr 11, 2007 | 07:33 AM
LukieLuc's Avatar
Default Re: (InvaderTrax)
how about the flex pipe, do i buy a new one or can i use the old one?
Old Apr 11, 2007 | 08:10 AM
94Vtecluder's Avatar
Default Re: (LukieLuc)
Man New York just keeps gettin ricier and ricier. If you have an H23 then do the mod, why not just go to any local shop/call them and find out for yourself. Some shops are capable of doing this and some aren't. Now if you have an H22 then take it back unless you are expecting near stock replacement.
Old Apr 11, 2007 | 08:35 AM
manbearpig's Avatar
Default Re: (94Vtecluder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InvaderTrax &raquo;</TD></TR><TR><TD CLASS="quote">Well, first off, most exhaust shops don't cary 2.5" flex pipes. You may be able to get them to put a donut gasket style flange on like on a Civic, which would work just as well, if not better. That being said, my quotes ranged from $100 to $200 for labor</TD></TR></TABLE>
My shop had one, charged me $80 to put a 2.5" collector with a flex pipe, on my megan header on my h22 I could notice a difference in higher rpms (i know most say that butt dynos dont count but I wasnt imagining a difference, also changed my exhaust note.)
Old Apr 11, 2007 | 01:46 PM
GraphiteMW's Avatar
Default Re: (*****)
I was quoted 75$
Old Apr 11, 2007 | 04:19 PM
LukieLuc's Avatar
Default Re: (GraphiteMW)
so with the collector mod of 2.5 inches, and heat wrapped headers, i should get some pretty good gains right??
Old Apr 11, 2007 | 06:19 PM
LukieLuc's Avatar
bump for ? above this
Old Apr 11, 2007 | 06:23 PM
manbearpig's Avatar
dont know if the megan racing is stainless or not.... but I've read that if it's a mild steel header, don't wrap it, or it will keep moisture in which = bad.
Old Apr 11, 2007 | 06:28 PM
I'm getting a flex pipe off eBay. Looks pretty good. I'll report back when it actually comes back in. Other than that, any performance shop can order one for about $40
Old Apr 11, 2007 | 09:44 PM
93sivtec's Avatar
U wont make any real gains.....it just helps the flow if u plan on doing something real with ur engine.....na build,or boost.But regardless of what anybody tells u,its going to be a little bit better than stock,but no 10hp to the wheels.Not to mention it really dosent matter if u dont have an 2.5"exhAUST. Hope this helps
Old Apr 17, 2007 | 06:08 PM
Got mine done today. Overall the butt dyno noticed a mild increase in the top end, with only a slight loss on the bottom. I ordered this pipe, and these guys sent had it to my house 3 business days later. Very high quality piece. Great job by them.
http://cgi.ebay.com/ebaymotors...81172
If I had to do it again, I'd go with a 2.25" because I'd like a little more bottom end, but it's still better than the 1.75" I had before
Old Apr 17, 2007 | 06:12 PM
Serenity Now!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InvaderTrax &raquo;</TD></TR><TR><TD CLASS="quote">Got mine done today. Overall the butt dyno noticed a mild increase in the top end, with only a slight loss on the bottom. I ordered this pipe, and these guys sent had it to my house 3 business days later. Very high quality piece. Great job by them.
If I had to do it again, I'd go with a 2.25" because I'd like a little more bottom end, but it's still better than the 1.75" I had before</TD></TR></TABLE>
looks like i know whats gonna be my next mod ^ ^
Old Apr 17, 2007 | 06:38 PM
MilanoLude's Avatar
Default Re: (93sivtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93sivtec &raquo;</TD></TR><TR><TD CLASS="quote">Not to mention it really dosent matter if u dont have an 2.5"exhAUST. Hope this helps</TD></TR></TABLE>
So this modification is still recommended for those who are using a 2.25 inch exhaust with a stock cat?
Old Apr 17, 2007 | 07:05 PM
If you have a stock cat, now would be an easy time to upgrade. I had my flex pipe welded directly to my cat
Old Apr 17, 2007 | 07:16 PM
LukieLuc's Avatar
i am removing the stock cat, and going to have just a 22" magnaflow resonator
Old Apr 20, 2007 | 10:16 AM
LukieLuc's Avatar
where do you place the o2 sensor once you do this mod in a 1995 honda prelude 4thgen
Old Apr 20, 2007 | 05:01 PM
Somewhere before the resonator. Your muffler shop will place it where it needs to be (IE where it was before)
jrhcivak
May 29, 2012 08:40 PM
xtrec02
Welding / Fabrication
Jun 25, 2009 12:24 PM
hb_guy
Sep 11, 2006 09:43 PM
brokenojoke
Jan 8, 2006 12:34 PM
JTCdudeman
Apr 30, 2005 10:31 AM
