Suspension & Brakes Theory, alignment, spring rates....
welding more subframe to prevent oilpan/downpipe damage?????????
Old Apr 10, 2007 | 05:59 PM
Smallpox33's Avatar
Default welding more subframe to prevent oilpan/downpipe damage?????????
ive gone through 3 downpipes, and 1 oil pan because i keep bottoming out on speedbumps driveways shitty roads.
has anyone fabricated some sort of extended crossmember or metal plates to stop this is it do-able????
i think this should be moved to wleding
Old Apr 10, 2007 | 06:22 PM
Smallpox33's Avatar
Default Re: welding more subframe to prevent oilpan/downpipe damage????????? (Smallpox33)
ok well it looks like i can get scrape plate but i cant find anything about it....
Old Apr 10, 2007 | 06:28 PM
Smallpox33's Avatar
c'mon anybody
i want to do this
Click to see Video
Old Apr 10, 2007 | 06:42 PM
Smallpox33's Avatar
https://honda-tech.com/zerothread?id=1636000
thats only underbody skid plate.
im thinking:
the header is the lowest point in the car, which gets smashed first, then the oil pan and then the crossmember....
if i were to just weld in bar of some sort, something to take the impact of the bottoming out
it would onlny have to be a CENTIMETER at most lower than the downpipe. and an inch thick.
this would be strong enough to take the bang and grind away...
no need for a skid plate, which is more for debris anyway.
Old Apr 10, 2007 | 11:26 PM
Smallpox33's Avatar
bump for any thoughts...
if i can get this engineered correctly, i could even consider selling them
no more dented oil pans/downpipes!!
Old Apr 11, 2007 | 07:09 AM
suspendedHatch's Avatar
Slam your ride, slam your oilpan.
Never had that problem.
Old Apr 11, 2007 | 07:37 AM
be.twenty's Avatar
i never had this problem either and i was slammed.
drive more cautiously or raise the car
Old Apr 11, 2007 | 07:59 AM
Smallpox33's Avatar
Default Re: (be.twenty)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by be.twenty &raquo;</TD></TR><TR><TD CLASS="quote">i never had this problem either and i was slammed.
drive more cautiously or raise the car</TD></TR></TABLE>
thats because youve never had to drive in a place with speed bumps, or pull in MY DRIVEWAY.
i rip my bumper off everytime i back out of the driveway, but i have to pull in the driveway to work on the car.
its about a solid 6 inch ledge....
and if you live in a place thats mountainous its worse...
my driveway sucks, and i have massive speed humps to my left and right of my driveway. its a hondas worst nightmare.
Old Apr 11, 2007 | 02:00 PM
YoungKadafi's Avatar
you seriously rip your back bumper off? i think that would be enough to raise the car up, plus I think slammed cars are out now. Its all about 15"-16" wheels and maybe a 1.5" drop if that.
Old Apr 11, 2007 | 02:07 PM
REDekSI's Avatar
Default Re: (YoungKadafi)
you have a good idea although i havent had those probs. i'd say find a good steel fabricator in your area if there are any thats the only suggestion i have
Old Apr 11, 2007 | 03:59 PM
Smallpox33's Avatar
Default Re: (REDekSI)
slammed cars arent in? i dont really give a **** about whats in... black widow body kits were "in" at one time do they look good? 15 inch wheels and a 1.5 inch drop screams WHEEL GAP. which is fugly. jdm is in, and i think some of it looks like ****...
now back to the topic.
i got another crossmemeber which im going to design and weld a scrape bar...
i wont have to worry about **** after that. and i can drive a slammed car fine.
i dont bottom out on the road anyways becuase i have good suspension, just high inclines.
Old Apr 11, 2007 | 07:29 PM
Han Solo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YoungKadafi &raquo;</TD></TR><TR><TD CLASS="quote">you seriously rip your back bumper off? i think that would be enough to raise the car up, plus I think slammed cars are out now. Its all about 15"-16" wheels and maybe a 1.5" drop if that.</TD></TR></TABLE> This scene has gone from rice to nice, from 18in wheels to 15in wheels, from hot rods to imports and from body kits to clean lips...However, one thing has always been true, the lower the better, the more dumped you are the better it is
CptHMCrunch
Jul 3, 2014 11:58 PM
JdmMidWest
Feb 20, 2012 05:20 PM
Legion
Feb 17, 2008 07:55 AM
Dave_B
Jul 14, 2006 08:09 PM
Quick 200k Mile Motor
Sep 26, 2002 11:04 PM
