CTR power folding mirror question???
Old Apr 10, 2007 | 05:50 PM
b18c inside's Avatar
Default CTR power folding mirror question???
I just installed my Power folding mirrors today. They look great. But anyway, my question concerns removing the JDM mirror glass and reusing my old mirror glass. It's crazy looking into a passenger side mirror on the driver side. Can this be done?? Is there a solution other than dealing with it? Can you replace the mirror glass with a USDM Integra mirror glass? Please help.
Old Apr 10, 2007 | 05:56 PM
Riced-EL's Avatar
I have a different question, is there a way to re-pin the harness and use the USDM harnesses???
Old Apr 15, 2007 | 07:26 AM
Si Jeff's Avatar
up for an answer
Old Apr 16, 2007 | 12:26 PM
bonh's Avatar
Speaking from Accords (which may help you) what we do is pull the USDM one out, if the backing is plastic you may be in luck. What we do is heat up that plastic/rubber until you can pull the mirror itself out. Be really careful in doing so. Do the same with the JDM one and swap them out. If you pick it at you can see how it can come out but its tightly fit, i'm going to be doing this today.. .because.. that **** is annoying as hell.. i'm scared to switch lanes to my left.
Old Apr 16, 2007 | 12:31 PM
Type X's Avatar
Default Re: CTR power folding mirror question??? (B18C inside)
I knew someone that did it back in the day.
however.... i never had the ***** to rip apart my ep3 power folding mirrors
i got used to the glass after a little while
thiendegigolo
May 5, 2011 03:34 PM
Nate047
72
Apr 3, 2007 08:55 AM
Tyson
May 31, 2006 03:17 PM
Slewbang
Apr 6, 2006 05:50 PM
colinproctor
Oct 7, 2004 08:48 PM
