need help- my 93 civic hatch running too rich
well id check your o2 sensor and if its not that you could have to big of a fuel pump i couldnt figure out why mine was running to rich until i looked and it was a walbro 255 on my n/a gsr so ya wats ur set up?
u have to explain ur set up for us to tell u nething really or are u running all stock d series ur going to want to run stock injectors unless u have hondata or any engine managment
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmbeegee »</TD></TR><TR><TD CLASS="quote">u have to explain ur set up for us to tell u nething really or are u running all stock d series ur going to want to run stock injectors unless u have hondata or any engine managment</TD></TR></TABLE>
he is telling the OP to list what mods are done to his car because honestly if any of us called someone for help and said that I can smell gas and oil and I think my car is running rich, I guarantee that they are not going to know where to start without knowing more info on the car.
So far we know d15b, 1 degree retartded, stock fpr, and a non working cel. Like what have you done recently to your car? How many miles? How old are the O2 sensors? Do you have any oil leaks...? stuff like this. Dont just start out saying that you have a problem without giving more info.
My .02
Modified by ntrider at 3:15 AM 4/11/2007
My .02
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ntrider »</TD></TR><TR><TD CLASS="quote">he is telling the OP to list what mods are done to his car because honestly if any of us called someone for help and said that I can smell gas and oil and I think my car is running rich, I guarantee that they are not going to know where to start without knowing more info on the car.
So far we know d15b, 1 degree retartded, stock fpr, and a non working cel. Like have you done recently to your car? How many miles? How old are the O2 sensors? Do you have any oil leaks...? stuff like this. Dont just start out saying that you have a problem without giving more info.
My .02
word y0!!
we need more info please
My .02
</TD></TR></TABLE>word y0!!
hey man check for the obvious first like leaks from the fuel filter, injectors, fuel rail, etc etc. Then if you can't find any leaks take the dipstick out and smell it. If it smells like gas really bad you may have bad piston rings. How does the car run? there are many reasons for problems so be specific and give a lot of detail. It helps the diagnosis go so much easier. Goodluck man.
U can feel fuel in the oil? just want to make sure that I am reading correctly. If done correctly a long blink of the cel is 10 and in the stickies is a list of cel codes and what they are.
But if fuel is in the oil then like what neil619 said good chance it is rings. Do a leak down test and compression test and let us know what the readings are.
pythoner
Dec 28, 2006 01:59 AM
