91 Accord Tachomter Jumps
Old Apr 10, 2007 | 02:52 PM
playerpimp73's Avatar
Default 91 Accord Tachomter Jumps
My accord has a problem with the tach jumping. Periodically when I press on the gas the tach will bounce around. Lately it's been bouncing and dipping. When it dips it sounds like it's bogging out and going to stall. I can't figure out if it's an igintion problem or the distributor.
Modified by playerpimp73 at 4:07 PM 4/10/2007
Modified by playerpimp73 at 6:31 PM 4/10/2007
Old Apr 10, 2007 | 03:09 PM
hondadude's Avatar
Default Re: 19?? Accord Tachomter Jumps (playerpimp73)
Tach bouncing and engine stumbles are usually a sign of a coil shorting out.
On your car I'd replace both Coil and Ignitor, as well as replace the plugs if they have a super sized gap and rounded off electrode
Old Apr 10, 2007 | 04:20 PM
Default Re: 91 Accord Tachomter Jumps (hondadude)
I'm looking at my Chilton's book and it doesn't mention anything about a ignition coil or ignitor. It has a self timing distributor.
It's a 1991 Accord LX.
Old Apr 11, 2007 | 09:52 AM
SkimN's Avatar
Default Re: 91 Accord Tachomter Jumps (playerpimp73)
could be the speed sensor, my buddies '90 used to do that, it would move around or sit at 0. can't remember if his engine stumbled
Old Apr 11, 2007 | 10:45 AM
Bruce Banner's Avatar
Default Re: 91 Accord Tachomter Jumps (skimNrace)
likely the dizzy, ignition wires etc..
Old Apr 11, 2007 | 11:28 AM
standbackimapro's Avatar
Friend had the same problem, Changed the coil ( his is a 92 dx) changed the coil and it still bounced around, so he changed the dizzy and the problem went away
The Chairman
Feb 25, 2013 03:23 PM
bcaslow
Jul 10, 2012 07:18 AM
gtkim
Dec 3, 2005 03:01 PM
siaczebra
Jun 29, 2003 08:24 PM
