Use stock type r ecu or tune with hondata?
My car is currently turbo right now, but I'm soon to be selling everything and going all motor. I will be swapping in a type r motor and I have the hondata s200b in my car right now. My question is, do I use the stock type r ecu alone? or can I use the s200 to have it tuned with even though its also got the boost option? What would you guys do?
use your current ecu and retune with the s200. the boost option doesnt mean anything since you dont have boost anymore.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x92preludesix »</TD></TR><TR><TD CLASS="quote">I can use my stock ls ecu with the motor and tune it using the hondata for the B18c5?</TD></TR></TABLE>
Unless it has been modified for VTEC operation, no. It also will not have the knock sensor board if you care about that. Neither does a P28.
i was assuming you already had a vtec ecu. you can convert that ecu to run vtec.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x92preludesix »</TD></TR><TR><TD CLASS="quote">well i plan on buying a complete B18c5 with ecu, so i should just use that ecu and tune that with hondata huh? </TD></TR></TABLE>
All of the P73 (ITR) ECUs are OBDII. Hondata is not applicable.
