notchy shifting
Old Apr 10, 2007 | 02:27 PM
20ls01's Avatar
Default notchy shifting
when i got my integra, it was not as notchy as it is now. i was able to slip into 1st with a lot less effort. going from 1st to 2nd it isnt smooth, rather notchy.
whats going on here?
is the transmission going?
need new fluid?
Old Apr 10, 2007 | 02:32 PM
im_poor's Avatar
Default Re: notchy shifting (20ls01)
how many miles on it? try changing the fluid.
Old Apr 10, 2007 | 02:52 PM
PLAGUED_DB7's Avatar
Default Re: notchy shifting (im_poor)
change the fluid.
Old Apr 10, 2007 | 03:38 PM
posHonda's Avatar
you are LUCKY to be having a teg with that low of miles...you shouldnt need syncromesh with that low of miles...get the honda mtf
Old Apr 10, 2007 | 05:06 PM
ThA IntegrA HI's Avatar
My cars is the same, I'll try that syncromesh stuff.
Old Apr 10, 2007 | 05:47 PM
twentyhurtz's Avatar
Default Re: (ThA IntegrA HI)
bud i dont' know, but i got my teg a year ago and had same issue, its like i had to notch around something from 1-2 gear, it sucked cause it caused me to miss 2nd alot when racing. but as of this moment, my car is sitting up waiting on a new tranny to come in, some shifter fork inside it broke completely in half,- was this prob caused by the notching over the last year, i don't know. just tellling you
Old Apr 10, 2007 | 10:20 PM
unknown0001's Avatar
Default Re: (20ls01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 20ls01 &raquo;</TD></TR><TR><TD CLASS="quote">55, 990 miles on it
should i use honda mtf or gm synchromesh?</TD></TR></TABLE>
Go pickup the GM Synchromesh High Friction Formula fluid and do a tranny flush with the fluid and then change it again with the GM Synchromesh fluid. It should help you with the shifting notch. If the fluid doesn't work after a few thousand miles...you might need to get a tranny someday
Old Apr 11, 2007 | 07:46 AM
Sam92Teg's Avatar
Default Re: (Mr.RHTuner)
You might also want to check your linkage under the car. Something could of hit your shift rod, stabilizer, or shifter from underneath. Just a thought.
Old Apr 11, 2007 | 10:08 AM
jizzer671's Avatar
Default Re: (Sam92Teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sam92Teg &raquo;</TD></TR><TR><TD CLASS="quote">You might also want to check your linkage under the car. Something could of hit your shift rod, stabilizer, or shifter from underneath. Just a thought.</TD></TR></TABLE>
yes, check all of those and maybe even check your clutch master cylinder. just another thought.
Old Apr 11, 2007 | 11:14 AM
Gearspeed-Performance's Avatar
Default Re: (jizzer671)
Check all the obvious before deeming the transmission bad. Also to the guy above...post pics of the broken shift fork...I would like to see it
Old Apr 11, 2007 | 12:56 PM
Where do you buy this?
r01516
Sep 3, 2008 10:54 PM
TopNotchR
Sep 24, 2004 06:50 PM
BrownGSR
Oct 13, 2003 02:01 PM
hmongdude
Jul 14, 2003 01:17 PM
fivespeedintegra
Jun 26, 2003 08:46 AM
