NO TOP END
Old Apr 10, 2007 | 11:49 AM
Luward's Avatar
Default NO TOP END
i have a:
95 b18c1
jdm type r piston
blox type b cams
skunk2 valve springs
rev valves
skunk2 manifold
rage header
custom 2.5 cat to the back
skunk2 cam gears set at 0,0
tune on crome pro - street tune
now for some reason. i have no top end at all. my mid feel pretty strong. but when vtec kicks it feels like it not going no where. i have not went to the dyno yet. but i was thinking. do i need more fuel on top? and my vtec right now is set at 5600. and my redline is at 8500. do you think i should get a fuel pump and a fuel pressure regulator and maybe injectors? i know that i need to go the dyno. but im preparing everything before i hit the dyno.
Old Apr 10, 2007 | 12:03 PM
Combustion Contraption's Avatar
Default Re: NO TOP END (Luward)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luward &raquo;</TD></TR><TR><TD CLASS="quote">
now for some reason. i have no top end at all. my mid feel pretty strong. but when vtec kicks it feels like it not going no where. i have not went to the dyno yet. </TD></TR></TABLE>
Then why even make a post at all?
Old Apr 10, 2007 | 12:25 PM
HerminShS's Avatar
B A N N E D
I think that 5600 for the vtec is too low for a gsr motor, I would do it in the 4800-5200 area.
And it sounds like you need more fuel at the top end.
Get the car to a dyno, that's really the only way that you would know for sure what you are missing
Old Apr 10, 2007 | 12:26 PM
Luward's Avatar
just seeing what you guys think. if i need anymore upgrades before i hit the dyno
Old Apr 10, 2007 | 01:01 PM
alterdcreations's Avatar
a tunable ecu
Old Apr 10, 2007 | 04:55 PM
Jay_Sensing's Avatar
Default Re: NO TOP END (alterdcreations)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alterdcreations &raquo;</TD></TR><TR><TD CLASS="quote">a tunable ecu </TD></TR></TABLE>
Yes, definately.
And if I remember correctly, blox type B's are similar (damn close actually) to Skunk 2 Stg2's. If so, then definately don't lower your vtec engagement. Just get the car on the dyno man.
Old Apr 10, 2007 | 07:42 PM
CaseBone's Avatar
Default Re: (HerminShS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HerminShS &raquo;</TD></TR><TR><TD CLASS="quote">I think that 5600 for the vtec is too low for a gsr motor, I would do it in the 4800-5200 area.
Read what you just posted!
Old Apr 10, 2007 | 07:59 PM
dbiker207's Avatar
Default Re: (G-Harry)
do u even have a wideband or anything. if you dont then how can u say street tuned, more like not tuned at all. if you do then whats the readings look like up top, they should be a maximum of 13.9:1 afr
Old Apr 11, 2007 | 12:33 AM
HerminShS's Avatar
B A N N E D
Y<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G-Harry &raquo;</TD></TR><TR><TD CLASS="quote">
Read what you just posted! </TD></TR></TABLE>
Uhm.... Yeah, Opps.
Thanks for the info......
Old Apr 11, 2007 | 12:43 PM
JDM_EK4_Coupe's Avatar
(banned)
Well if you dont have a tune on the car what do you expect? Whenever you do a significant change to a motor such as Cams or Pistons you change how the engine was originally intended to operate. Get it tuned with a Hondata or Crome and you should see good results.
Old Apr 13, 2007 | 10:56 AM
Luward's Avatar
my friend tune my car. and yes we use a wideband to tune
milano2kdc2
18
Mar 6, 2005 08:36 PM
DA-nteg
Aug 23, 2003 04:34 AM
JdoggsGSR
Apr 28, 2002 10:32 AM
RedTeg95
Apr 25, 2002 07:45 PM
Mr. Softee
Feb 10, 2002 09:11 AM
