I need an injector that is PLUG and PLAY
310cc part number ACC-153310 at http://www.Summitracing.com I believe... don't know what spray pattern they are, or if Accel makes a good injector, but I'm curious. $263.80 plus the standard S/H fee... Think I'd just find a good deal on RC and solder in the clips... Bout the same price...
Does Accel injectors plug in without the GM harness?
.....that's the $1M question.
[Modified by Spoon1, 7:12 AM 5/28/2002]
I think your best bet might be s2000 injectors, but you will have to double check the cc
https://honda-tech.com/zerothread?id=182623
Here's an interesting thread:
Looks like s2k injectors should fit your bill.....
Tuan, what did you end up doing?
ok, Mike K you know how to install the injectors and solder them on to the wiring and stuff correct?? if so I'll pick me up a set of RC injectors, what size do you reccommend 310/370/440? obviously since I have hondata wouldn't 440 do the trick??
