del Sol JDM cluster help
Old Apr 10, 2007 | 10:51 AM
Pinoyjava's Avatar
Default del Sol JDM cluster help
I have a 96 del Sol and i just bought a Jdm guage cluster. the problem is.. the jdm cluster doesnt have a **** to adjust the dimmer of the guages. Its permanently dim, too dim for my liking. what can i do the make it brighter? any ideas????
Old Apr 10, 2007 | 01:15 PM
fdavie's Avatar
Default Re: del Sol JDM cluster help (Pinoyjava)
I think the JDM clusters had some sort of "auto-adjust" feature where they sensed the light... can't find the post where that was, might have been on a different board.
Anyway, you could try to trick that sensor into thinking it was always dark, or somehow swap the adjuster from a USDM cluster into your JDM... or swap the gauges from your JDM into your USDM.
Old Apr 11, 2007 | 12:22 PM
Pinoyjava's Avatar
Default Re: del Sol JDM cluster help (fdavie)
Cool... ive never heard about that auto adjusting mechanism but i'll try to do more research on it. thanks though
Old Apr 11, 2007 | 12:33 PM
94WhYt_EG1's Avatar
how much did you get it for?
Old Apr 20, 2007 | 09:45 AM
EG2 SiR's Avatar
Default Re: del Sol JDM cluster help (94WhYt_EG1)
To the best of my memory; the port for the potentiometer (dimmer ****) still exists on the back of the JDM cluster. I THINK you have to remove a plastic plate to get to it though. You will also need to just adjust it and leave the entire device behind the cluster as, obviously, there is no hole for it to go through on the JDM unit.
enot767
Nov 5, 2009 04:22 PM
tbud454
Jan 15, 2004 02:02 PM
whoDAT
Oct 18, 2003 02:05 PM
mr2kqql
12
Sep 4, 2003 01:02 PM
