high rev low rev
Old Apr 10, 2007 | 10:05 AM
hatchbackv-tech's Avatar
Default high rev low rev
ok heres the deal.its a b-16 a the problem is when i first start it it revs high and low untill it warms up then it will stop i have replaced the idle controlll valve but no changes can some one please help me out.
Old Apr 10, 2007 | 10:16 AM
HXvtec's Avatar
Default Re: high rev low rev (hatchbackv-tech)
sounds fine to me. you car revs higher when you first start up to warm the car up quicker
Old Apr 10, 2007 | 10:18 AM
Default Re: high rev low rev (HXvtec)
i really dont think so.but thx for ur in-put.
Old Apr 10, 2007 | 10:20 AM
WickedHonda00's Avatar
well what is your suggestion then?
Old Apr 10, 2007 | 10:21 AM
MR.johnson's Avatar
thats normal dude.
Default Re: (WickedHonda00)
thats kinda why i postd it on here no need for ur comment it has nothing to do with what the question is.
this is to wickedhonda
Old Apr 10, 2007 | 10:25 AM
Default Re: high rev low rev (MR.johnson)
well i really hope so.if anyone else has an idea please feel free to post.
Old Apr 10, 2007 | 10:28 AM
BubblegumTate's Avatar
It's normal for an engine to idle high while it is warming up, then once it warms to normal operating temp, the idle drops.
If you are talking about the idle surging quickly between high and low rpm, then you probably either have a vacuum problem or a cooling problem. On all of my Hondas, I've solved the surging idle either by fixing a vacuum leak, or fixing the cooling system.
Old Apr 10, 2007 | 10:34 AM
Default Re: high rev low rev (BubblegumTate)
im going to take carb cleaner and spray around the engine and see if i have a leak.but yes high rev then low rev its not normal......it revs high then low kinda fast but it does it for about ten 15 min untill the temp hits right above the first mark and the v-tec dont kick in till it warms up to.
Modified by hatchbackv-tech at 12:40 PM 4/10/2007
Old Apr 10, 2007 | 10:52 AM
HXvtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchbackv-tech &raquo;</TD></TR><TR><TD CLASS="quote">im going to take carb cleaner and spray around the engine and see if i have a leak.but yes high rev then low rev its not normal.</TD></TR></TABLE>
if it surges then you have a prob like bubblegum said. if you first start the car and it stays around 2000rpm then 10 min later its at 1000rpm thats fine. if it goes up and down you have a prob. what exactly is it doing.
d0wnShiFt
Aug 5, 2018 01:32 PM
wi_accord
Jan 3, 2006 01:52 PM
