jdm h22 ek w/ twm itbs
I just put some twm itbs on my h22 and I cannot rev out the car its popping and breaking up like its has way to much fuel..I turned vafc down to -30 and still the same thing. I have 400 cc Injectors and a walbro 255 fuel pump, need help this **** is ridiculous.
ITB's with a VAFC....interesting....did you try adjusting your vtec crossover? maybe that will help...
ok
seriously
get
it
tuned!
ok
seriously
get
it
tuned!
Your exactly right in saying It is ridiculous, but I say the ridiculous thing is you are running itb's with no tuning and are simply playing with a vafc hoping to get it to run perfect.
GET IT TUNED. with real engine managment not a crap vafc.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK9Type S »</TD></TR><TR><TD CLASS="quote">i tried using crome and it had the same problem so i swapped ecu and said wtf lemme try it. the other ecu ran better than the crome ecu so we decided to put the afc on it.</TD></TR></TABLE>
if you couldnt get it running with Crome, i suggest going to a different tuner. If you did not get it tuned and only ran a "chip" thats your own fault for not getting it tuned properly. ITB's are NOT BOLT ONS.
not to mention you are running larger injectors and a larger fuel pump. A vafc cant even control those injectors, then you throw ITB's and a high pressure fuel pump into the mix and you will get a poorly running car.
I had ITB's on an h22 about 5 yrs ago and went out on the street and tuned it with a vafc and had it drivable not running to rich. But then went with a wideband in the car and got it to about 13.7a/f then vafc was prolly -35 throughout if i remember right.
