mpfi and an automatic tranny
Old Apr 10, 2007 | 05:17 AM
rbwdriven's Avatar
Default mpfi and an automatic tranny
Ok has this been done and if so is there a write up anywhere.
A friend has a 91 civic dx hatch back.
It has the automatic tranny in it.
His wife will be driving the car so we cannot change the tranny.
He is planning on doing the dpfi to mpfi swap.
He has purchased the si intake manifold, dizzy, injector wiring and resistor box.
My question is what ECU do we need to run to keep the auto tranny. And how do we wire up the engine bay.
I would assume we use the standard dpfi to mpfi swap but the auto tranny is throwing me.
Thanks
Old Apr 10, 2007 | 05:25 AM
ChickenH's Avatar
the si ecu . you will loose torque converter lockup (overdrive) but you can hook it to a switch to turn it on or off when you want. and you have to ground some wire to make the shift lock disengauge
Old Apr 10, 2007 | 05:39 AM
alupso's Avatar
If you can find it, you can use a PS9 ECU from a 1988-91 Civic EX, they were autos with MPFI.
Old Apr 10, 2007 | 06:05 AM
BoostinCrix's Avatar
Default Re: mpfi and an automatic tranny (rbwdriven)
you will also need the throttle body from the ex civic since it has a place for the auto tranny throttle linkage
Old Apr 10, 2007 | 08:25 AM
Jonknee's Avatar
Default Re: mpfi and an automatic tranny (BoostinCrix)
yeah i think the only issue will be the stupid lockup control solenoid thingy ontop of the tranny, use a switch like the other dude said, who knows when u have to flip that switch on.
Old Apr 10, 2007 | 10:41 AM
crex23's Avatar
Default Re: mpfi and an automatic tranny (Jonknee)
http://www.fourthgenhatch.net/mpfi.html
Use this link, its what I used when I did the mpfi on my auto CRX. Like the other guys said, you will A) need to use a PS9 ecu and B) need to use a throttle body with dual wheels for throttle cable and kickdown cable, the manual TB won't work, trust me. Both the ecu and throttle body can be found in the 90-91 Civic EX automatics. Everything else is cake.
Old Apr 10, 2007 | 10:46 AM
IT GUY's Avatar
Default Re: mpfi and an automatic tranny (crex23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alupso &raquo;</TD></TR><TR><TD CLASS="quote">If you can find it, you can use a PS9 ECU from a 1988-91 Civic EX, they were autos with MPFI. </TD></TR></TABLE>
Old Apr 10, 2007 | 12:17 PM
ludesrv's Avatar
You just need an automatic Si ecu. I'm pretty sure a junkyard around here has a few of them. I'll take a look see if you want me too. IM me.
Old Apr 10, 2007 | 01:37 PM
janz3n's Avatar
Default Re: (ludesrv)
can you use an mpfi auto TB for a manual car?
Old Apr 11, 2007 | 07:10 AM
ChickenH's Avatar
I actually liked the switch option to turn off the torque convertor lockup and i just used the 89 crx si ecu and a later model ex auto intake, TB.
Old Apr 17, 2007 | 04:34 AM
rbwdriven's Avatar
so it is now looking like I'm in the market for those products.
auto ecu, auto throttle body and linkage between throttle body and tranny.
Thanks
bonies
24
Aug 30, 2009 11:00 PM
mengy007
May 21, 2006 05:26 PM
mengy007
May 10, 2006 08:10 AM
Charlie Moua
Feb 24, 2003 08:44 AM
Vinceg99
13
Dec 19, 2002 11:20 AM
