MINI-ME HIGH IDLE
I have a 90 crx si and I just did mini me yesterday y8 head and d16a6 bottom end. I started it and the idle is around 3k rpm. I did not remove the intake manifold completely from the car. i just backed it away. the throttle cable and all stayed in its original position. I tested for vacuum leaks also.Could I be off on timing?(it runs great just the high idle).The car is still obd-0 . If there is not enough coolant could the idle skyrocket from that. Help me out if you can.
96gts4.6l
Feb 10, 2009 01:27 PM
PINKS
May 29, 2006 10:26 PM
