Suspension & Brakes Theory, alignment, spring rates....
under brace instalations:
Old Apr 9, 2007 | 08:42 PM
JDM5075's Avatar
Default tanabe under brace
Has anyone on here installed a tanabe under brace on a DC2 or EG here? did you get intructions with yours? I didn't get any!
Modified by JDM5075 at 10:28 PM 4/9/2007
Old Apr 10, 2007 | 07:39 PM
JDM5075's Avatar
Default Re: tanabe under brace (JDM5075)
BUMP
Thanks in advance for any reply's!
Old May 7, 2007 | 08:10 PM
cueballsi's Avatar
it is the same thing as one of those megan H- brace bars...... just unbolt the front bolts holding in the A arm in the front, and 1 bolt from each side hold in the sub frame... bolt up the front frist... loose tight .... then the rears.... after all four bolts in are hand threaded...... then tighten them down like no other
civicservice
13
Apr 1, 2018 05:39 AM
bdubnyc
13
May 13, 2008 10:16 AM
jweezy225
Dec 18, 2004 05:54 PM
ls_vtec_crx
Apr 21, 2004 05:16 PM
01CWITR
Aug 7, 2002 03:52 PM
