COde 7 (Throttle Position Sensor)
Noob here, i recently diagnosis my car using the thread feature here on the site, the CEL flash 7 times, quick flashes, i check under the code, and TPS, is what i got, i went to a local junkyard and pick one up, installed it and reset the ecu. I unplugged to ecu fuse even disconnect the brain, the CEL is still on, need help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blk007 »</TD></TR><TR><TD CLASS="quote">suppose the one you picked up from the junkyard is no good also? Was the cel on before you diagnosed the car? or only when you diagnosed it..then it showed up? </TD></TR></TABLE>
x2 on the also broke tps- happend to me when i put on my b18 throttle body
the diagnosis i got was before me changing the TPS, but where i bought the TPS, all their cars they dismantle does not have a check engine light on it( so they say), the CEL also appear after me swapping the TPS,..
its very unlikely you have purchased a bad tps.. it's a potentiometer type sensor. after you have it set to .45v close with key on engine off. then go to your ecu and de-pin d22 on your ecu and make sure it is a good connection
gotta calibrate it.
get a multimeter.
tap the positive into the middle wire (i think its red/blue) and ground the ground
turn key to on
make sure it reads appx .45v closed throttle, if it doesnt, turn it until it does.
then go WOT and make sure it reads appx 4.5-5.0v
once it reads those, tighten it down, reset ecu, be happy.
get a multimeter.
turn key to on
hi all, i have just completed a h22 swap in to a 98 civic ek. all is good apart from code 7 same as previously mentioned. it runs ok put when i take it for a drive it is guttless and has no top end power. could anyone give me some advise on what to change or rectify.
thanks Matt
thanks Matt
asianeric
Sep 11, 2009 09:35 AM
Rayog21
Aug 26, 2009 08:31 AM
