240cc injectors, instead of 345's, bogging?!?
Old Apr 9, 2007 | 08:12 PM
Dat1BVtecN's Avatar
Default 240cc injectors, instead of 345's, bogging?!?
My friend has a 93 H22 motor and is using 240cc's injectors right now for the mean time. When he got the motor their were no injectors nor the resistor box, so i had spare 240cc's to let him use. The car bogs major and doesnt wanna rev around past 3,500 rpm. You think down grading from 345's to 240's would cause this? Stock motor everything. let me kno wat you guys think
Old Apr 9, 2007 | 08:14 PM
thegeorge613's Avatar
Default Re: 240cc injectors, instead of 345's, bogging?!? (Dat1BVtecN)
I think it would cause some fuel starvation, so it's in safe mode right now to prevent stuff from going way wrong.
P13_mein's Avatar
yes
got to go bigger
Old Apr 9, 2007 | 08:20 PM
high_revs's Avatar
running lean
Old Apr 9, 2007 | 09:03 PM
ciremulb5's Avatar
Default Re: (h2b_eg8)
Way too small of injectors, kick it back up to the 345s or go bigger and get fuel management, like S300
Old Apr 9, 2007 | 09:08 PM
98vtec's Avatar
moderator emeritus
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h2b_eg8 &raquo;</TD></TR><TR><TD CLASS="quote">running lean</TD></TR></TABLE>
bingo.
Old Apr 9, 2007 | 09:31 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: (98vtec)
One of my injectors took a ****. So I went to Pepboys and got new ones(Buddy hook up). Car ran like **** and wouldnt rev past 5000. Turns out Pepboys gave me the wrong injectors. They beleive all obd1 ludes use the same injectors. (245cc) Well I work at Midas so I decided to go through one of our parts vendors. Same problem. With 2 diffrent vendors. Finally broke down and paid for em from Majestic Honda. You gotta use the right injectors...
Old Apr 9, 2007 | 10:04 PM
streamlineluder's Avatar
if my memory is right h22s came with 290, 310 , and 345s you could probably make the 240s work with an aftermarket FPR but the injectors would probably be close to full duty cycle, which will wear them out fairly quick. The 345s prolly run at 60% duty cycle or less. A switch back to 345s (or bigger) should fix it, if not you may want to consider a new fuel pump, although it would be a rare occasion to hear a stock h22 hit fuel cut. HAHA.
Old Apr 10, 2007 | 05:18 AM
high_revs's Avatar
obd1 h22 comes with 345's
obd2 h22 comes with 290's
none ever cae with 310's no honda actually comes with those
Old Apr 10, 2007 | 07:31 AM
flyrod's Avatar
You can probably tune it to run on 240s, but don't push it because it will go lean on top as you max out duty cycle. Or, you can crank up the fuel pressure. Either way will get you going until you can get the right ones...
Old Apr 10, 2007 | 04:55 PM
high_revs's Avatar
just get the right ones
civic_jones
Sep 7, 2008 10:43 PM
tarheelsoldier
Mar 28, 2007 11:44 AM
russianswty
27
Nov 14, 2006 06:30 PM
Eg_TypeR
May 11, 2006 10:26 AM
Bintegra
14
Jul 29, 2004 08:11 PM
