Will a Civic lowering kit fit my Del Sol?
Will Tein lowering kits for a 95 Civic fit my 95 Del Sol? I was just wondering because I found a great price when I searched lowering kits for Del Sol and the link led me to a kit for a 95 Civic. Thanks guys.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JJSpecTuning »</TD></TR><TR><TD CLASS="quote">yeah it'll work</TD></TR></TABLE>
Yep.
Check the spring-rates and see if you'll even like them or if they're close enough to springs made for your car.
Yep.
pretty much any honda springs will fit any honda. just depends on the weight of the car to do the lowing. if you put civic springs on an accord its ganna lower it more than it would a civic cause the accord is heviear. or the other way around it probly wont lower the civic cause it is not heavy enough. just depends on the spring rate and the wieght of the car.
yes it will work a del sol is a civic technically, they droped the del sol from the civic line later on and finally made it just honda del sol, but most of the parts are interchangeable, but ill definatly have to say that the del sols definatly have way beter styling than the regular EGs, definatly ahead of the time, yeah for HONDA!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whit3 »</TD></TR><TR><TD CLASS="quote">pretty much any honda springs will fit any honda. just depends on the weight of the car to do the lowing. if you put civic springs on an accord its ganna lower it more than it would a civic cause the accord is heviear. or the other way around it probly wont lower the civic cause it is not heavy enough. just depends on the spring rate and the wieght of the car.</TD></TR></TABLE>
1st bold. Totally wrong brother. You think CRV springs fit on an 89 crx?
2nd bold. Wow.
Pretty much any 92-00 civic and 94-01 integra sprigns are interchangeable. Though risky because of different spring rates and spring design.
Ef springs only fit on Ef series and Crxs.
tein springs for an EK do not look the same when lowered on EG tein springs due to different spring /rates.
2nd bold. Wow.
12Zodiac
Feb 14, 2011 01:48 PM
cevinklark
Sep 4, 2006 01:55 PM
terribl3jon
Aug 31, 2004 09:09 PM
