Trunk Leak Help
My friends got a 94 integra 2door, it rained 2 days ago and opened his trunk today and his trunk was filled with water. Has anyone else had the same problems or kno where its coming from and how to fix it?
check this article http://www.team-integra.net/se...D=546
most tegs have that problem...it might be coming from the opening between the tail lights and your body...you gotta search it there should be a article and pictures of it...but all you gotta do is get some silicone and fill in the gap between the taillight and the body
If it has a sunroof, you should also check the two drain hoses... They run behind the side panels, and are kinda a pain in the a$$ to get too, but i hear sometimes they disconnect themselves - draining water into your spare tire well
Check your taillight seals and check the seal around the trunk as well. There may be a tear in it.
If you like working on your car(s) take apart the interior trim peices and have a friend sit in the car while someone else uses the hose on it and see where the water is comming in from and chase it from there.
-Rik
-Rik
It is most likely either the 2 drain tubes from the sunroof if it has one, or the 1 drain tube from the electric antenna. Sometimes these hoses get clogged or un-plugged and they let water into the hatch area.
Thanks for the pics - I have tried everything from checking the sunroof drains to changing the tailight gaskets, but i still get water not only in my trunk , but IN my driver side tailight. Maybe this will help...
i have the same problem and will try that
but water also makes its way to the carpet in front of the back seat so the floor is pretty much soaked. is this the same problem???
951dc5
10
Jan 30, 2008 08:21 AM
