How much stronger are the jdm 36mm axles over the 32mm usdm
Old Apr 9, 2007 | 05:41 PM
motormike40's Avatar
Default How much stronger are the jdm 36mm axles over the 32mm usdm
How much stronger (whp/wtq) are the jdm 36mm axles over the 32mm usdm axles? Thanks
Old Apr 9, 2007 | 05:42 PM
cltitus's Avatar
Default Re: How much stronger are the jdm 36mm axles over the 32mm usdm (motormike40)
i think they are they same but the jdm ones might be just a tad bit stronger if your looking for strength.
driveshafts 2.9 axles way to go
Old Apr 9, 2007 | 06:00 PM
Cool, thanks for the info.
Old Apr 9, 2007 | 06:35 PM
ZygSpeed's Avatar
Default Re: How much stronger are the jdm 36mm axles over the 32mm usdm (cltitus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cltitus &raquo;</TD></TR><TR><TD CLASS="quote">i think they are they same but the jdm ones might be just a tad bit stronger if your looking for strength. </TD></TR></TABLE>
WTF does that mean?
One of them is is 12.5% thicker!
Old Apr 9, 2007 | 08:17 PM
ITR#132's Avatar
Is the "36mm axle nut" axle thicker than the "32mm axle nut" axle? I always thought the shaft was the same only the outer hub was different.
Old Apr 10, 2007 | 05:39 AM
ZygSpeed's Avatar
Default Re: (ITR#132)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR#132 &raquo;</TD></TR><TR><TD CLASS="quote">Is the "36mm axle nut" axle thicker than the "32mm axle nut" axle? I always thought the shaft was the same only the outer hub was different.</TD></TR></TABLE>
Correct.
And the outer hub area is where I'm told they often break when drag racing w/slicks and dropping the clutch.
phatbuddha
May 29, 2013 04:25 AM
nonvteclude
Aug 7, 2006 08:45 PM
GarageAlchemist
Jul 20, 2006 06:38 PM
NstyGrnHatch
10
Feb 15, 2005 11:35 AM
crxgsr91
Oct 22, 2004 02:51 PM
