After hundreds of dollars, all I needed was a Fuel Filter to stop my car from stalling!
Old Apr 9, 2007 | 04:54 PM
JBirch_97Prelude's Avatar
Default After hundreds of dollars, all I needed was a Fuel Filter to stop my car from stalling!
After several post in this forum I finally fixed my Prelude "Idle & Stalling" problem. All it took was a fuel filter. I purchased a EGR Valve, Map Sensor, and a Chipped OBD1 ECU which worked but the car ran bad. As soon as I started the car with the OBD2 ECU in after changing the filter I can notice a big difference.
Now all I have to do is figure out why my ECU keeps throwing "Random misfire codes and I will be ready to start adding mods to my car.
Old Apr 9, 2007 | 04:59 PM
GraphiteMW's Avatar
Default Re: After hundreds of dollars, all I needed was a Fuel Filter to stop my car from stalling! (JBirch_
Thats why you replace the cheapest stuff first then work your way up
Old Apr 9, 2007 | 10:44 PM
streamlineluder's Avatar
It's really amazing all the problems caused by a bad fuel filter, and they're all so misleading.
Old Apr 10, 2007 | 07:01 AM
GtechPro's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by streamlineluder &raquo;</TD></TR><TR><TD CLASS="quote"> It's really amazing all the problems caused by a bad fuel filter, and they're all so misleading. </TD></TR></TABLE>
Can't really blame the filter, unless there was a factory defect (which is rare). Otherwise, the only way a filter will go bad is if you let it go bad by not replacing it on time. $25 and 10 minutes of your time - that's all it takes to prevent this from happening.
But yes, I agree. The problems caused by it can be misleading.
Old Apr 10, 2007 | 01:57 PM
It's still throwing codes so, I am going to replace the Air Filter now.
Old Apr 10, 2007 | 01:58 PM
vinuneuro's Avatar
Adjust your valve lash.
Old Apr 10, 2007 | 06:09 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinuneuro &raquo;</TD></TR><TR><TD CLASS="quote">Adjust your valve lash.</TD></TR></TABLE>
I am sorry but what is a valve lash?
Old Apr 10, 2007 | 07:16 PM
zirac50's Avatar
it's the clearance between the rocker and the camshaft. I agree with cuz that solved my random misfire code. basically adjust the clearance to spec.
aznoophi
Apr 2, 2008 09:52 AM
jmaz
Honda Civic (2006 - 2015)
Aug 8, 2007 04:30 AM
youknowimwhite
Feb 2, 2007 07:43 AM
chahsiubow
Nov 24, 2006 01:12 PM
swiftstyles
Dec 24, 2004 08:29 AM
