Access to radio antenna?
Apoligize in advance if theres a thread already.....Im looking to just disable my antenna, as I have no use for fm/am stations. I still use the cd player though. I looked at the trunk and I dont see any panels, except the left and right panels for rear strut tower. Any help?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P Nut »</TD></TR><TR><TD CLASS="quote">Just put a switch for the antenna in the ashtray area in case you need it in the future.</TD></TR></TABLE>
Pull your radio, find the "power antenna" wire in the harness, cut it, crimp a male connector on one side and a female on the other. Your power antenna will no longer come up until you plug the two wire halves back together. Desired result... easily reversed
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MatrixShark »</TD></TR><TR><TD CLASS="quote">
Oooor, just put in a $3 switch from radio shack. More aesthetically pleasing result.
</TD></TR></TABLE>Oooor, just put in a $3 switch from radio shack. More aesthetically pleasing result.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sfedai0 »</TD></TR><TR><TD CLASS="quote">Im not sure I want to take out the HU just for the antenna. How do you take apart hte plastic panel in the trunk?</TD></TR></TABLE>
Trust me it's much easier to take out the HU than the interior rear trim panel... That trim panel is one large piece that runs from the door to the boot... also requires you to remove the back seat to get to it. Not that difficult, just more work than pulling out the HU....
