would I run into any problems using Jun III's...
Old May 27, 2002 | 12:07 PM
No-Gi's Avatar
Default would I run into any problems using Jun III's...
I have a Pr3 head with Crower dual springs and tit. retainers. I am going to be installing a set of Jun III's this Week and I am concerned about compatability issues. Is there anything to be concerned about? Also, I am not going to use Jun cam gears as I have a set from another company. Has anyone found that Jun cams need to be used with their cam gears like todas? TIA
Old May 27, 2002 | 12:18 PM
canuck-mx6's Avatar
Default Re: would I run into any problems using Jun III's... (B16aEK)
Well, I can tell you one thing. If anything happens to your cams and you want JUN to warranty the cams, you should use the JUN valvesprings, or you will run into trouble with warranty claims.
Jun cams work with other companies cam gears, I was using Skunk 2's, but I am using JUN now.
Old May 27, 2002 | 12:23 PM
No-Gi's Avatar
Default Re: would I run into any problems using Jun III's... (canuck-mx6)
The cams are used anyways, so I dont think I can claim anything. They have about 7000 miles
Old May 27, 2002 | 12:28 PM
Hybrid ctr's Avatar
I don't think you will run into any problems but personally I don't really trust Crower products. Any cam gear is fine, I like Skunk2
Old May 27, 2002 | 12:33 PM
No-Gi's Avatar
Default Re: would I run into any problems using Jun III's... (Hybrid ctr)
Yea I am a bit skeptical on crower but I have reved the car to 9000 with no prob. I hope I dont run into **** later on.
Old May 27, 2002 | 12:34 PM
Hybrid ctr's Avatar
Also consider getting a Power Entreprise timing belt
Old May 27, 2002 | 12:42 PM
Chubz's Avatar
use the JUN springs. Crower springs arent made for the extreme pressure JUN III put on the valvesprings during vtec.
Old May 27, 2002 | 01:52 PM
No-Gi's Avatar
Default Re: would I run into any problems using Jun III's... (SuperTech)
Thanks for all the input guys... Once I get a baseline with the Jun's Ill post it so you guys can flame me
Old May 28, 2002 | 06:52 AM
GReddyB18C's Avatar
The Crower 68185 valve springs cannont handle a cam with more than 12.0 mm of lift. Their Stage 3 (63403) VTEC cam has a lift of 11.9888 mm (0.472 in.). Using a cam with more lift than this will lead to coil bind and you will damage your motor.
Cheers.
-Shawn
Old May 28, 2002 | 07:35 AM
Cheap Bastard's Avatar
New User
Get Jun valve springs. It's not that Crower is bad, it's just Jun's valve spring and cams were designed to work together.
I use Crower Ti retainers with my Jun3 cams and valve spring.
CB
Old May 28, 2002 | 10:29 AM
canuck-mx6's Avatar
Default Re: would I run into any problems using Jun III's... (highpsi)
You guys are nuts. . . your a little skeptical on Crower??????!!!!!!!
There parts are in the 3-4 second top fuel 5000 hp cars and have been around for ever.But you would trust Jun because why?
Because I have seen too many motors grenaded when Crower components fail, and I have heard too many negative stories regarding warranty issues. Because a manufacturer is great at making parts for domestics doesn't mean that they are great at making parts for Japanese motors
Old May 28, 2002 | 11:01 AM
slowerthanu's Avatar
New User
WoWeeee, I never knew they used Crower Honda Valve springs in Top Fuel cars, thats super neato. I always thought they used purpose built components specifically for 5000 horsepower cars!
Old May 28, 2002 | 11:02 AM
New User
Default Re: would I run into any problems using Jun III's... (slowerthanu)
Oh and BTW, I run All JUN components, I dont mix and match.
Old May 28, 2002 | 11:04 AM
azn98R's Avatar
Same here... knock on wood, but so far so good here
JDMlyfestyle
Apr 29, 2004 09:31 AM
jeremy.
32
Dec 31, 2003 08:47 AM
jessevtec
Sep 2, 2003 02:06 PM
topspeed86
24
Jul 21, 2003 02:23 PM
AllMotorITR
Jul 7, 2002 03:40 PM
