Suspension & Brakes Theory, alignment, spring rates....
CRX Suspension question:
Old Apr 9, 2007 | 11:32 AM
channy's Avatar
Default CRX Suspension question:
Question for the suspension / CRX gurus. I have an 88' CRX with the 90-93 Integra rear disk conversion and ST sway bars. I was wondering if anyone could tell me what type of coilovers specifically I have to run?
I attempted to search but really didn't get the results I was looking for. From the people I've talked to, no one really knew for sure and since I have to order the K Sports from Vancouver it would be nice to ensure I have the correct ones. My question is, will I need to go with the integra rear coilovers and CRX fronts, or what should I do?
Old Apr 9, 2007 | 03:05 PM
gringo7718's Avatar
Default Re: CRX Suspension question: (channy)
The suspension you need is for the crx (all 4 corners). It all depends which lower control arms you have.
In 1988 the rear lower contorl arms were different than the 89-91 cars. This means the shock mounts to the rear lower contol arm differently in the 1988s. If you have the "box type" (1988) rear lower control arms then you need shocks that work for 1988. If you have the other style rear lower control arms, you need shocks for 89-91
Old Apr 9, 2007 | 03:07 PM
gringo7718's Avatar
datcrxnigg
Suspension & Brakes
Sep 18, 2015 03:14 AM
sean burke
Suspension & Brakes
Dec 27, 2009 08:19 AM
Skipper75
14
Apr 21, 2007 12:34 PM
