Ignition Coil? need help fast!
Old Apr 9, 2007 | 08:22 AM
InfraRed's Avatar
Default Ignition Coil? need help fast!
Hey,
Last night i went to start my car after leaving it at my girlfriend's overnight, and to my disappointment, it wouldn't start. It will make the noise as if it will turn over but it just keeps turning and turning and turning but won't start.
I called a friend and he walked me through the steps to check my spark plugs to see if i got a spark. Well, no spark. He told me it was probably the ignition coil.
If it is in fact the ignition coil, when i go into Discount Auto what motor do i tell them the coil is for? I have LS/VTEC.
Once I get this coil, how do I go about installing it? My friend told me that all i really needed was a phillips head screwdriver.
Any input and help would be greatly appreciated. I need to get this in ASAP.
Old Apr 9, 2007 | 08:24 AM
97Ej6mike's Avatar
SInce its LS VTEC, you have a GSR ( im assuming) head. Since the problem is located in the head, you need to get the Coil for a GSR motor, so tell them its an Acura Integra GSR
As for installation, search the tech and DIY threads, but from what ive seen, it isnt all that complicated.
Old Apr 9, 2007 | 08:29 AM
InfraRed's Avatar
thanks for the response!
i have a b16 head. i tried searching ignition coil but no luck...i'll try again.
Old Apr 9, 2007 | 08:33 AM
InfraRed's Avatar
ah didnt search archived
Old Apr 9, 2007 | 09:13 AM
SkoundrelUSA's Avatar
cute little bastard
Default Re: (InfraRed)
so get a coil for a 95 Del Sol VTEC. if its an OBD1 B16 distributor on there that is
Old Apr 9, 2007 | 09:22 AM
del_slow420's Avatar
Default Re: (SkoundrelUSA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA &raquo;</TD></TR><TR><TD CLASS="quote">so get a coil for a 95 Del Sol VTEC. if its an OBD1 B16 distributor on there that is</TD></TR></TABLE>
or if its obd2 get one for 99 civic si
fastlimegreencivic
Classic Hondas
May 5, 2010 05:30 PM
95blackEG
Dec 24, 2008 07:59 PM
R6INIT
19
Jul 24, 2006 07:40 PM
seifer
Feb 15, 2005 09:23 AM
