Built/Sleeved GSR engine and Other parts (Aeromotive, Fluidampr, Catchcan, Injector driver, scatter
Buyer Flaked, Re-listing
Built Engine $4500 FIRM
b18c1 block 83 mm brand new sleeves from Benson
GSR crank balanced and micro-polished from Benson
CP pistons 83mm 9:1
Pauter Rods
Cometic head gasket
ARP main studs
ARP head studs
ACL bearings
GSR head ported by Portflow
Ferrea valves
Portflow springs and titanium retainers
Stock cams
New ITR oil pump
New ITR water pump
10AN oil drain welded on to the pan
NEVER RUN, BRAND NEW! PRICE IS FIRM.
Moroso catchcan (2 12AN) for ports on valve cover with GSR valve cover with 2 12AN fittings off the front (Moroso is same can Endyn uses) Brand new with all lines - SOLD
Fluidampr Used, SOLD
Full-Race cam gears New but were mounted SOLD
AEM Injector Driver New - 250
Aeromotive A1000 fuel pump, mounted and primed but never ran - $225
Boomslang obd2-obd1 Harnesses - $75
Mazworx b series scatter shield for Tilton style clutch, new - SOLD
Avid Racing B series mounts, new style, brand new $325
If paying with paypal add 3.3%
Modified by N20civicB18 at 12:52 PM 4/9/2007
Modified by N20civicB18 at 5:08 PM 4/11/2007
Modified by N20civicB18 at 5:07 PM 4/22/2007
Modified by N20civicB18 at 3:47 AM 4/27/2007
Modified by N20civicB18 at 2:18 PM 6/5/2007
CP pistons 83mm 9:1
Pauter Rods
Cometic head gasket
ARP main studs
ARP head studs
ACL bearings
Ferrea valves
Stock cams
New ITR oil pump
New ITR water pump
Kyle@Oceanstatetuning.com - paypal and email
boosted.si04
Oct 23, 2011 08:47 PM
