engine running really funny. Need advice.
Oh Kay. When start driving my car lag big time. Theres a funny sound coming from the engine like a blog sound and back fire noise from the tailpipe. Im guessing to much fuel, I check my fuel pressure is at 45psi. And my smells really bad. Stinky! And the rpm drop when i give it alittle gas. Im lost and dont know where to start.
Yeah there is one P0108 for high pressure input but the pressure is normal. And I have a broken kknock sensor from trying to take off the oil filter. haha my fault.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maomaniarocks »</TD></TR><TR><TD CLASS="quote">Yeah there is one P0108 for high pressure input but the pressure is normal. And I have a broken kknock sensor from trying to take off the oil filter. haha my fault. </TD></TR></TABLE>
Code P0108 is indicative of a bad MAP sensor, which could cause your problem. It is running rich because the bad sensor is telling the ECU that the manifold pressure is high.
I though the same thing but i borrowed friends map sensor, reset the check engine and after a few seconds after i start the car it will pop back on. Well its not going to go away because of the broken knock sensor. But when i run the code reader the same code pops up and my car still run weird. Yeah this car is starting to be a pain in the a*s.
Check this:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by im_poor »</TD></TR><TR><TD CLASS="quote">did you accidently swap the map and tps connectors? just a thought.</TD></TR></TABLE>
It is a common wiring mistake.
yeah that was the first thing i thought of so switch it around once started and it was worst and cant rev up the 3000rpm. So i had it right the first time. and my car eat alot of gas i mean ALOT.
3easy21
Aug 2, 2013 05:48 PM
EK79
Apr 12, 2006 07:27 AM
kay_animation
Jan 17, 2003 12:01 AM
