diy topmount - first manifold
First off just want to say thanks for all the great info on this board. Just wanted to share a few pics of my manifold that I have been working on. I am a complete noob to building manifolds, but after lots and lots of reading and researching I felt confident enough to have a go at it. The manifold is just tacked up for now but I will be welding it together sometime this week.
Btw I am a rebel and I am using the HF $200 tig toaster. Before I weld this thing up im going to setup a back-purge line.
One thing im concerned about is preventing warpage on the flanges when I weld it up. Would it be worth it to go get a 3/4-1" flat stock and bolt the header flange down when I weld it? Thanks
I use some brand new chinese head casting that were sent to me for a rebuild that I rejected because the castings were crap. The manifold surfaces were flat though so I have 2 clean heads to mount the head flanges too, Aluminum really helps pull heat out of the flange quickly, with steel it will take a while.
I don't know about where you are but try to find someone local who has a trashed head. As long as the flange area is clean your set. I got a destroyed and stripped dseries head from a friend who had it laying out in the rain
. Try to find something like that
Nice! Deff use a heat sink when welding the head/turbo flange. My first manifold was a ramhorn, a little intimidating at first but you just have to get off the computer and do it.
Your collector opening to the t3 flange came out great
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbosi03 »</TD></TR><TR><TD CLASS="quote">looks good
Is it the best way to tack the entire mani then weld all at once? Seems like you wont be able to get at all the welds..?</TD></TR></TABLE>
Nope, before I weld it I am going to have to dismount each runner individually, weld it and then reinstall the runner to the collector and the flange....oh so much fun
my buddy had an extra ls head so im gonna use that to prevent flange warpage. Unfortunatly I ran out of argon today while building my downpipe so gonna have to wait a little to get the mani welded up. Ill post pics of my welds when im done with the manifold.
