Brake light flashes????
Old Apr 8, 2007 | 07:28 PM
Knight1's Avatar
Default Brake light flashes????
Recently tonight i noticed if i am take a deep turn or curve epecially on a on/off ramp the brake light on the dash came on, and when i straightened up, it went off, i thought maybe my e-brake was pulled up a bit, but it wasnt. I wasnt braking at all in the turn and it came on and than on the turn again i used my brakes but it still stayed. Since it was night time i couldnt look at my brake reservior, so I will check it first thing in the morning so see the fluid level...but if its not the fluid level, what could it be?
Cliff: When I am taking a big curve or turn the brake light comes on and than goes away when i straighten up.
Old Apr 8, 2007 | 07:38 PM
immrtaltchnq's Avatar
Default Re: Brake light flashes???? (Knight1)
probably low fluid or it splashes below the full level around turns
probably should at a little
Old Apr 8, 2007 | 07:51 PM
deadline's Avatar
yeah...probably low fluids or e-brake lines need to be tighten up ?......
Old Apr 8, 2007 | 07:57 PM
Default Re: (deadline)
probably not the lines
theres a switch at the ebrake handle that triggers the light
Old Apr 8, 2007 | 09:40 PM
billyinse's Avatar
Default Re: (immrtaltchnq)
i had that problem in my hatch the wire on the bottom of the e-brake was bent up and making the light come on over bumpsi just bent it back down
shocker911
Oct 7, 2010 04:24 PM
MaWeiTao
Aug 8, 2010 12:49 PM
91H4hatch
Feb 17, 2007 07:15 AM
intech
Nov 17, 2005 02:44 PM
92SleeperH23
Dec 21, 2004 10:02 PM
