Where in socal to get wheel studs replaced?
Old Apr 8, 2007 | 07:24 PM
erikiksaz1's Avatar
Default Where in socal to get wheel studs replaced?
This is a silly question, I know, but there's a reason. I've been reading countless wheel stud replacement threads and there doesn't seem to be a definitive answer as to whether or not wheel bearings will be damaged in the process of replacing the wheel studs.
Some say that if you use the ghetto hammer method to remove the hub, the bearings will get damaged. Others say that a press will be the only thing to save the bearings.
So, my question is, what shops in socal do you guys trust to change out your studs without farking up the bearings? My bearings seem fine right now, so I don't see a point in replacing them...
I ended up going to Auto Star in Walnut. They charged me 35 bucks, w/o parts.
Modified by erikiksaz1 at 12:38 AM 4/16/2007
Old Apr 8, 2007 | 08:02 PM
immrtaltchnq's Avatar
Default Re: Where in socal to get wheel studs replaced? (erikiksaz1)
you can def replace wheel studs without damaging anything, just spin the hub and theres a little part in the back like a gap you can tap them out at then put new ones in
Old Apr 8, 2007 | 09:43 PM
erikiksaz1's Avatar
Default Re: Where in socal to get wheel studs replaced? (immrtaltchnq)
That works with the front wheel studs?
Old Apr 8, 2007 | 09:54 PM
yea you might have to clean off the back part some to find the gap cause of build up but it should work
Old Apr 8, 2007 | 10:07 PM
dc2long's Avatar
LEADFOOT AUTOMOTIVE
they charged me 25 per wheel if you bring your own studs. 1.99 from kragen
other places charge 75-100
they do a good job too.
Old Apr 8, 2007 | 11:04 PM
erikiksaz1's Avatar
Default Re: Where in socal to get wheel studs replaced? (LTgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LTgsr &raquo;</TD></TR><TR><TD CLASS="quote">LEADFOOT AUTOMOTIVE
they do a good job too.</TD></TR></TABLE>
Fremont's up north buddy
Old Apr 9, 2007 | 08:32 AM
Sam92Teg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by immrtaltchnq &raquo;</TD></TR><TR><TD CLASS="quote">you can def replace wheel studs without damaging anything, just spin the hub and theres a little part in the back like a gap you can tap them out at then put new ones in</TD></TR></TABLE>
Depends on what car he has. Some have access to remove the studs, some don't. Your avatar shows an Integra, the front hubs do not have access to pound the studs out. Go pull your front tire, and take a pic if you see where the studs can be knocked out.
I have heard of grinding the studs and grinding the hubs to make room, but I think I will rent a hub puller before doing that.
B_Swapped93
Mar 29, 2014 08:44 PM
SlowB16
15
Jun 16, 2008 12:37 PM
SlowB16
Jun 11, 2008 07:00 AM
Tyson
22
Jul 13, 2002 03:45 PM
blackEF
May 2, 2002 07:04 PM
