help, gsr fuel pump install on EF??
Old May 27, 2002 | 09:54 AM
Eggman's Avatar
Default help, gsr fuel pump install on EF??
installing gsr fuel pump in my 89 civic si right NOW. after dropping the tank and pulling out my stock pump i noticed that my stock pump is much larger than the so called gsr pump. did the salvage yard sell my something else or is the gsr pump suppose to be smaller?
thanks,
charles?
Old May 27, 2002 | 10:24 AM
raene's Avatar
Default Re: help, gsr fuel pump install on EF?? (Eggman)
That's right. The stocker is larger than the GSR pump. What I did is use the tubing to put the GSR pump kind of into the stock location and then zap-strap it to the brace, taking care to avoid actual contact with the metal brace by positioning it with the rubber isolator at the end of the bracket. It sounds like mumbo-jumbo but try and see if you know what I mean
Old May 27, 2002 | 10:52 AM
Eggman's Avatar
Default Re: help, gsr fuel pump install on EF?? (raene)
which filter do you end up using?
thanks,
charles
[Modified by Eggman, 11:52 AM 5/27/2002]
Old May 27, 2002 | 11:02 AM
Eggman's Avatar
thats strange. i just checked http://www.hondaautomotiveparts.com and they list 3 different fuel pumps for an 89 si civic. 1 fuel pump for 88-89 crx si. and 1 fuel pump for ALL 90-91 civic/crxs.
Old May 27, 2002 | 12:01 PM
raene's Avatar
Damn, that is weird. The filter itself is the stock CRX one, since it mounts in the engine bay. Are you talking about the filter baggie on the end of the pump itself?
Old May 28, 2002 | 08:36 AM
Eggman's Avatar
yeah which filter aggie did you use on the pump, stock or gsr?
thanks,
charles
motormike40
Aug 19, 2006 07:32 PM
enhancedCL9
Mar 19, 2003 05:16 AM
Eggman
May 27, 2002 10:33 AM
